To replace injectors or to not?
#47
If your using the AIS intake make sure you use the sleeve threw the fender as well. I think the S&B would be a better option but I do like the AIS as well. Also it mitt smoke a little down low still you up grade the turbo. Need that air. Your on your way, it will be a hole new truck when your done. Do what Stewart showed you, My trans runs really cool with that cooler.
#48
Yea I'm adding gauge and sensor. Stock sensor in my excursion hasn't been to accurate. Never been over 220 deg but yet I'm on my 3rd transmission.
#49
I'm done with washable filters. I've hated my afe since I got it. As much as I drive id rather buy disposable filters. That's why the AIS caught my eye.
#50
Riffraff Diesel 6637 Ford 7.3L Powerstroke Intake Filter Kit
I too have the AFE filter on my Excursion. It's the AFE Stage 2. And compared the 6637 I have on my F250? I'd rather have the 6637, hands down.
Whenever you feel like the 6637 is dirty, you swap it for a new one.
The only reason I haven't switched the Ex over is because I still have cleaner and oil left for the AFE and i'm too broke not to get the full return on my investment.
Stewart
#51
#52
#53
I see no problem with my setup. would cooler be better? Sure probably but MAT is important not AIT.
Edited to make more sense.
#54
If your 6.0 style trans cooler suffered thru one of the trans failures, it is likely to have debris in it that will continue to kill the next transmission. It is very hard to clean that type of cooler. The conventional wisdom is don't bother to try. Get a new one because failure is too expensive.
Let you tuner know you have the JW valve body so they can factor that in, otherwise shifts can be pretty harsh.
Definitely sleeve the AIS due to the big injectors.
#55
I can only post the results I got, as best as I can remember. And while the test was less than scientific, and it was done almost 20 years ago, IIRC the significant difference in temps only occurred when moving slower than 20mph.
I'm a fairly simple guy and am far from an engineer or scientist, but if that were true, we wouldn't be talking about the heat of the engine affecting the temp before it enters the engine, or am I confused? (Standard SOP for me, LOL)
The ambient temp and the conditions being driven will affect the temp of the air entering the filter and that temp does matter.
The point I was making was, once moving near city driving speed, the heat generated underhood only affects the air temp entering the filter slightly (subjective definition/term) and isn't a concern, in my opinion.
Stewart
The air temp into the filter has little to do with the temp of the air entering the engine due to the intercooler.
Stewart
#56
#57
I've purchased the AIS system for both of my trucks already. The second I saw the description for upgraded intake with disposable filters I was sold instantly. So 6637 is out of the question with both intakes sitting in my shop waiting to get installed. Not saying the 6637 is bad, but it looks like one of those DIY filters the ricers run. I like the factory look of the AIS.
#59
I would like cooler temps for the incoming air. may need to build a enclosure for the filter and test.
poor blurry picture. I may have something funny going on not sure. Driving to work pulling the toyhauler 60mph up a little hill in OD (left it in 4th after this) about 68 degrees ambient -------- 113 underhood IAT behind filter --------- 86 MAT after intercooler
