Vacuum lines?
Old Jun 1, 2017 | 08:19 PM
LeviD's Avatar
LeviD
Vacuum lines?
How many vacuum lines are there on a 79 400? My truck is idling rough after running for 5-10 minutes. Now I know I keep getting stuff in the little dinky fuel filter as I have replaced 3 already because the truck sat for so long now that it's been driving and running with gas in it stuff in the tank has been loosening up I believe. I just want to check all my vacuum lines as well to be sure.
Old Jun 1, 2017 | 10:20 PM
PapaBearYuma's Avatar
PapaBearYuma
The number of lines depends on a lot of things:
Factory AC will have one
Power brakes will have one
PCV is a vacuum line
Automatic transmission will have one
Ported vacuum for distributors advance
EGR will have at least one
Thermostat housing may have two
Air cleaner may have one or two
Cruse control may have one
You likely have one or two vacuum cans
Check the condition of your hoses and caps. Some will be hard to see, as they may be on the back side of the carburetor. Then put a gauge on, and check the reading
Ford77Pickup
Mar 2, 2017 09:06 AM
'92 Ford
Jul 5, 2016 03:19 PM
solo pilot
39
Jan 16, 2014 11:16 PM
nolls
May 6, 2009 08:00 PM
Jrock909
Jun 15, 2003 09:15 PM
