which is better?
Old Jun 1, 2017 | 02:01 PM
dreamofford's Avatar
dreamofford
Smile which is better?
an older alternator with an external regulator or a newer on that is internally regulated?
Old Jun 1, 2017 | 02:20 PM
Ford_Six's Avatar
Ford_Six
Newer internally regulated. A 3G type from a Taurus is a great upgrade on the older diesels, not sure of the fit on these trucks though.
Old Jun 1, 2017 | 07:20 PM
dreamofford
i will try. i went to another website and got the diagrams
Old Jun 1, 2017 | 11:39 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Definitely the 3G alternators are better. The regulator is smooth and long-lasting. Better for new accessories and electronics. There is one or two 'internal' fans, plus the outside one. They continue putting out higher currents even after extended times and higher temps. The diode heatsink is better, and there are replacements that are supposed to be extremely good.
Avoid the re-wound high-output aftermarket ones. They only work better at higher RPMs, and work worse at low Rs where we drive. Chrome and 'one-wire' are less desirable. You want the sensor wire going up under the dash, to sense voltage after resistance between the battery, and the headlight switch. (See topics on web.)
You may want a two-groove pulley. Cold-weather squeal can be a minor annoyance for a second or two. You can run it tighter as the belt stretches at the beginning.
Get the red plastic B+ insulating elbow to move the connection outboard, and give more clearance on the backside.
Cooling air goes in the back. I made a heat shield plate to go behind the alternator, so it breathes the cooler air in front, rather than the air off the exhaust manifold. It was a Las Vegas mod, for very high temps, so consider this extra.
Make two fusible links. Use the flame-proof fusible link wire. There is a formula for the wire size/length, but I don't have it handy. The expensive fuses are silly in my opinion. They are sized too large to avoid surge-pops, but you don't want that in the alternator-to-battery connection.
After this, you may put your headlights on relays, with short and heavy wires more directly. In any case, you will love the brighter lights all over the truck.
Old Aug 2, 2017 | 01:33 PM
dreamofford
thanks i will try those suggestions
thekingofcows
27
Sep 23, 2019 10:14 PM
joshofalltrades
Electrical Systems/Wiring
Nov 30, 2012 02:58 PM
3004speed
Aug 2, 2010 04:16 AM
skattnig
19
Feb 14, 2010 10:37 PM
SHEFFBOY2
Jul 17, 2008 07:48 AM
