Sponsored by: Auxito
Acc / Lighter plug stays on
Old May 31, 2017 | 08:58 AM
Barnstorm's Avatar
Barnstorm
I have a 97 F150 XL. The lighter plugs stay on even with the key removed. I just bought this truck and this seems to be odd behavior to me, yet I can find no modified wiring.
Old May 31, 2017 | 09:38 AM
Bluegrass 7's Avatar
Bluegrass 7
Are you referring to the cigar lighter and aux outlets?
If yes they are never on a switch in Ford vehicles 97 to 04.
Good luck.
Old May 31, 2017 | 09:42 AM
Barnstorm's Avatar
Barnstorm
Good luck.
Yes, the aux and cigar.
I would expect these to turn OFF with the ignition.
Are you saying that they stay hot all the time?
Old May 31, 2017 | 09:56 AM
Bluegrass 7
That's what I said....not being switched.
Only in the later trucks are the outlets controlled with timed and load sensing functions.
In your truck the circuit is good for 10 amps max.
If you want to turn off any port install a relay that will pull up with ignition and drop when turned off.
Good luck..
Old May 31, 2017 | 10:07 AM
Barnstorm's Avatar
Barnstorm
Good luck..
That's what I needed to know, Thanks!
ChancesDad
Nov 27, 2009 08:48 AM
supertruck
1997 - 2003 F150
Jan 29, 2007 05:55 PM
Rory_Johnson
Electrical Systems/Wiring
Dec 25, 2005 09:47 PM
SmilinSam
Apr 11, 2004 12:51 PM
boomupguy
1997 - 2003 F150
Mar 2, 2004 03:24 PM
