Ignition Switch interchangability
Old Apr 9, 2004 | 07:06 AM
SmilinSam's Avatar
SmilinSam
Are the Ignition switches(not the key part but the part with the wiring connector block that the key actuates with the rod)) interchangable from 1981-1985? or are there differences?
Old Apr 11, 2004 | 12:36 PM
Franklin2's Avatar
Franklin2
I believe if you have fuel injection, they are different. An easy way to find out is go to partsamerica.com(advance auto), napaonline.com or autozone.com. Plug in each truck year and find the switch. Write down the part no. and then plug in the other truck and see if the same part no. comes up.
Old Apr 11, 2004 | 12:51 PM
SmilinSam's Avatar
SmilinSam
Thanks for the reply, I'll try that.
Both Trucks I have sitting here are using carbs.
Thanks,
Sam
