Engine swap??
Old May 30, 2017 | 11:10 PM
Digdug67's Avatar
Digdug67
Engine swap??
Bought a 2002 f-250 7.3, it has a wonderful window in the block.lol
Also bought a 97 7.3 to replace the windowed engine.
#1 will the heads on the 2002 work on the 97 block?
#2 can i use single shot injectors on the 2002 heads?
#3 is there a difference in the short blocks?
Thank you
Old May 30, 2017 | 11:23 PM
Bubba Jones's Avatar
Bubba Jones
I'm not 100 percent sure on this but I believe:
1. They should be the same heads so Yes (if I'm not wrong) they will work
2. Yes you can, many people swap that over HOWEVER you must get the 2002 computer tuned for single shots if you use single shots with the super duty computer.
3. These are the differences in the blocks I can think of:
- The super duty short blocks had their connecting rods on the bottom end manufactured differently. It's often desirable to get an OBS block for the connecting rods were considered to be stronger.
- The super duty motors have a different front cover and HPOP. HPOPs are interchangeable between covers, and super duty covers should bolt up to OBS blocks
- The serpentine belt brackets are different between OBS and SD motors so the entire serpentine setup would need to be swapped between motors (should bolt on fine if swapping to the same front cover)
Old May 31, 2017 | 12:19 AM
Digdug67's Avatar
Digdug67
Thanks Bubba Jones
Old May 31, 2017 | 08:20 AM
farmert's Avatar
farmert
The fuel systems are different between the two. The Superduty does not have the lobe. on the cam, to run the mechanical fuel pump the OBS trucks run, as the NBS trucks use an electric fuel pump.
Old Jul 25, 2017 | 03:12 AM
Digdug67's Avatar
Digdug67
Update:
I am planning on only using the short block from the 97 and putting the 02 heads and other components on the 97. Will this work as long as I plug the extra hole in the block for the mechanical fuel pump??
z31freakify
Jul 7, 2017 07:15 AM
Gettysburg150
Jun 16, 2015 07:10 AM
simplejack
Aug 22, 2012 10:06 PM
Furian
Aug 2, 2011 04:55 PM
hwypntr
Aug 17, 2003 03:30 PM
