Offroad & 4x4
95 4 X 4 LO problem
Old May 28, 2017 | 08:32 AM
HaydukeLives's Avatar
HaydukeLives
95 4 X 4 LO problem
I own a 95 F 250 super Cab XLT with a manual shifting transfer-case. I can not get it to shift into 4 LO. Goes from 2 to 4 HI no problem. Even when I put my weight on it, it won't push down to engage 4 LO.
Old May 28, 2017 | 08:01 PM
*2fords*'s Avatar
*2fords*
Try putting the transmission in neutral, then push down on the **** as you pull back on the lever.
Old May 29, 2017 | 07:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
also, some of these transfer cases you had to pull to the driver side then back when in neutral to get it in 4 low.
if the shifter does not say push down, it is probably a pull left style
push down style:
pull left style:
Old May 30, 2017 | 05:42 AM
HaydukeLives
My lever is the push down style. I can get it to move to 4 HI but can't get it to push down. I was just wondering if anyone else had this problem.
Old May 30, 2017 | 06:48 AM
tjc transport
i ain't rite
if it is in neutral when you are trying to go into 4 low, the issue is going to be corrosion between the shifter plates due to lack of use.
do not try to force it, you will only break the shifter. the fix is to remove the shifter, disassemble it, clean it, lube it good, and put it all back together.
Cheapthrills
Mar 15, 2019 04:46 PM
96_F250_Deezal
Oct 17, 2018 08:27 PM
RSpence75
Jun 25, 2014 04:00 AM
bronco4x4cali
Bronco II
Aug 3, 2012 11:22 PM
ToeCutter66
Sep 12, 2005 12:16 PM
