1978 - 1996 Big Bronco
A/C PROBLEMS!!!
Old May 26, 2017 | 08:09 PM
Dababy100's Avatar
Dababy100
A/C PROBLEMS!!!
I have an 89 bronco. A/C works but goes to defrost at 30+ mph then goes almost off after that till I slow way down then comes back on. Any help would be awesome. Also it has no overdrive switch in it. Is this normal?
Old May 26, 2017 | 10:08 PM
grumpin's Avatar
grumpin
I would check for a vacuum leak.
Old May 28, 2017 | 12:18 AM
Torky2's Avatar
Torky2
Originally Posted by Dababy100
I have an 89 bronco............. Also it has no overdrive switch in it. Is this normal?
In 1989, the only Ford 4 speed automatic was the AOD, which was mechanically shifted, not electrically. No overdrive ON/OFF switch. To select non-overdrive operation, i.e., only gears 1-2-3, pick the proper DRIVE shift quadrant position for it. Same for allowing O/D (4th gear) operation. The "allow O/D operation" position usually is a "D" with an "O" around it. The non-overdrive position is just a "D".
Another possibility is that you have a 3-speed automatic, the C6. In which case the shift quadrant only has one "D" position.
The93GreyGhost
20
May 18, 2015 08:51 PM
302flareside1992
Dec 11, 2011 03:22 PM
coreyh
Jan 8, 2005 11:11 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Dec 9, 2003 10:10 PM
