My 4speed to 3 speed swap
Nice work ! I always admire the guys that have the lathes and know how to use them. I was wondering what you did to the 4 speed mount to make it work on the 3speed transmission? I did this swap in my 48 F68 but I used the three speed mount and modified the crossmember. I want to do put a three speed into my M3 and any help would be appreciated. , Doug.
[QUOTE=Muppy1840;16944520]Nice work ! I always admire the guys that have the lathes and know how to use them. I was wondering what you did to the 4 speed mount to make it work on the 3speed transmission? I did this swap in my 48 F68 but I used the three speed mount and modified the crossmember. I want to do put a three speed into my M3 and any help would be appreciated. , Doug.[/QUOT
I made this
Look like this
This was my first radius
Does that help?
I made this
Look like this
Does that help?
So the outside seal stays the same and you use the yoke from the four speed? If I take my three speed mount and four speed mount to a machine shop the can just copy the three speed dimensions? How do you think the speedo will work with this setup? Thanks , Doug.
