Inside Door Handle Stuck
Old May 25, 2017 | 07:41 PM
baallinger's Avatar
baallinger
Thumbs up Inside Door Handle Stuck
My drivers inside door Handle on my 1995 F-150 would not lift to open the door. I found there is a small rubber button that the handle lever rests. That little button about the thickness of a penny had moved out of place keeping the mechanism from going just over center. I replaced the little rubber button and now it works great. While having the door panel off I sprayed all moving parts with aerosol white lithium grease. Works smoother than ever.
Old May 25, 2017 | 09:28 PM
sandymane's Avatar
sandymane
Good going. There is a thread called "What have you done to your truck today" You should find it on the first few pages. Post this there as I'm sure there are people there that would like to hear this.
Old May 26, 2017 | 01:06 AM
Glenn54's Avatar
Glenn54
I'm interested in where this small rubber button is located. I replace the cable on the driver's side of my 95 F150 because the door was difficult to open from the inside and outside. I'm in the process of doing the same for the passenger door. Can you post a picture of the button? Thanks.
Bovaloe
Sep 14, 2017 12:56 PM
firsttofight11b
16
Dec 18, 2016 02:17 PM
1984_6.9
17
Aug 1, 2016 12:00 PM
JRB65
Jul 30, 2009 11:47 AM
rfreidel
Jun 12, 2008 04:47 AM
