Dash lights
Old 05-25-2017, 09:14 AM
Bearhugger1933's Avatar
Bearhugger1933
Bearhugger1933 is offline
Dash lights
My dash lights are going out,how hard are they to change out.
Thanks jim
Old 05-25-2017, 04:39 PM
Red97350's Avatar
Red97350
Red97350 is offline
Are you referring to the lights in your dash cluster? They aren't too bad to replace, there's probably a dozen or so of them.
Disconnect batteries
Remove trim pieces on dash cover and screws
Remove headlight switch ****
Remove dash cover
Remove gauge cluster by removing 8? screws
Replace bulbs
This is mostly it, but i'm probably forgetting something.
Red
Old 05-25-2017, 05:01 PM
Bearhugger1933
Thanks,where would.you get them.
Old 05-25-2017, 05:55 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is online now
Your owners manual should list what they are.
Old 05-25-2017, 06:07 PM
Red97350's Avatar
Red97350
Red97350 is offline
I believe they are GE 194. I would look online or try walmart. they will probably be cheaper than the auto parts store.
Red
Old 05-25-2017, 08:47 PM
Bearhugger1933
Thanks I will look into these.jim
Old 05-25-2017, 08:59 PM
Red97350's Avatar
Red97350
Red97350 is offline
The numbers should be on the bulbs. If I wasn't so lazy, I would go downstairs and double check. Be aware of flipping the cluster over on it's face. There is a sticker on the cluster not to do so. There are 3 plugs you will have to disconnect to remove the cluster out of the dash.
Red
Old 05-26-2017, 02:02 PM
owenbg1011's Avatar
owenbg1011
owenbg1011 is offline
anyone have any tips for removing the cluster. My wires are a little on the short side which is making it slightly harder then I would like to get the cluster out.
Old 05-26-2017, 07:16 PM
Red97350's Avatar
Red97350
Red97350 is offline
If you flip it on its back you *should* be able to disconnect the 3 sets of wires. If you have big hands, you may not be able to do it.
Red
Old 05-31-2017, 10:54 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
Dash bulb replacement:
File Type: doc
Old 05-31-2017, 10:59 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Some pics
ligito
05-12-2009 12:12 AM
Tim Young
10-01-2008 02:46 PM
hank_48
02-10-2005 01:21 PM
gunner9821
Electrical Systems/Wiring
02-04-2005 12:14 AM
danr
1997 - 2003 F150
09-22-2004 06:44 AM
Quick Reply: Dash lights
