Replacement fuel pump for '94 E350 7.5L
Old May 24, 2017 | 04:11 PM
ogarcia434's Avatar
ogarcia434
I need to replace the fuel pump on my 1994 E350 Club Wagon with the 460. What specs should I look for in terms of gph and psi? Does my van use a single pump or dual pumps (I have one single fuel tank). The reason I ask is because my 2002 F150 HD uses two pumps.
Thanks in advance.
Old May 25, 2017 | 04:22 PM
ogarcia434's Avatar
ogarcia434
I want to use a Walbro fuel pump. I looked at the Walbro site and they show a part number TU200 43.5 psi and 33 GPH. I looked on eBay and there is a listing for a GSS-340 which they claim puts out 67 GPH. Which one is correct for my 1994 E350 wiith the 460.
Thank You
Old May 26, 2017 | 09:34 AM
annaleigh's Avatar
annaleigh
My newest van is a 1988 so I have never worked on a 94 but Rockauto lists
MOTORCRAFT PFS46 {#F6PZ9H307BB} Sender Assembly Info
Stripped Chassis; E-350 Econoline Base Model; w/ Aft Axle Fuel Tank (Only 3 Remaining)
MOTORCRAFT PFS47 {#F6PU9H307CB, F6PZ9H307CB} Sender Assembly Info
w/ Midship Fuel Tank (Only 3 Remaining)
1994 FORD E-350 7.5L V8 Fuel Pump & Housing Assembly | RockAuto
They also list these pumps for the 94 w/460
1994 FORD E-350 7.5L V8 Fuel Pump | RockAuto
they also list this part under fuel tank reservoir
BOSCH 67000 Fuel Pump Module without Flange Info
Center Tank
1994 FORD E-350 7.5L V8 Fuel Pump Reservoir | RockAuto
All i see listed is a single pump... My 1988 uses two pumps also... i have no idea on the psi.. But they do list both Motorcraft pumps which would be correct.
Though I think $350 is ridiculous, I find many aftermarket parts turn out to be junk or at least a crap shoot. As I write this I wonder what I would do if the $350 high pressure motorcraft pump went out on my van when the others are $80. I would probably think about a salvage yard first.
Old May 26, 2017 | 10:40 AM
ogarcia434's Avatar
ogarcia434
Thanks Annaleigh,
RockAuto is usually my first stop. I saw the prices on the Mototrcraft and decided to pass on it. Last year I got a really good deal on a Walbro on eBay, pump for my F150 HD. Found a Walbro GSS340 for $89. on ebay that I am going to order soon.
Thank You
Ted Burc
Jun 1, 2018 06:00 PM
gman97005
Jan 29, 2015 08:49 PM
jimboo
Aug 31, 2011 07:56 PM
wrangler
Sep 28, 2003 07:58 PM
larrysb
Nov 21, 2002 12:28 PM
