Worn Leaf Spring Bolts
Old May 21, 2017 | 09:35 PM
crazy96863's Avatar
crazy96863
Would you change these? Worn right to the bottom of the threads close to the shank... The shank is also worn a bit. I am on the fence as to whether or not its necessary but if a quality replacement is readily available I am all for it to eliminate the uncertainty.
Any recommendations on a good source for these?
Old May 21, 2017 | 10:12 PM
crazy96863's Avatar
crazy96863
nevermind... found some NOS on ebay for $17.49... Cheaper than some soft chinese made aftermarket bolts I found. Should have looked a bit harder before asking.
Old May 22, 2017 | 01:08 PM
D-rat's Avatar
D-rat
assume you meant the Ubolts? Sounds like you found a set, but if you have a local trailer or spring shops, many of them will bend those up to spec while you wait. That's another option in the future.
Old May 22, 2017 | 01:10 PM
crazy96863's Avatar
crazy96863
Nope. Already got those. These are for the spring eye/shackle. Super lift makes a great set of ubolts for $35 at summit though. Thx.
robertbruce
Jun 21, 2013 11:53 PM
andyj ford driver
18
Oct 1, 2011 01:03 PM
sufferingant
May 21, 2010 06:26 PM
cabloom300
Sep 8, 2009 07:36 AM
77' f-100 ranger xlt
May 1, 2004 07:33 PM
