Grease Zerks
Old May 21, 2017 | 01:18 PM
PlatinumScorpion's Avatar
PlatinumScorpion
Grease Zerks
Where and how many on the 2017s? Anybody know?
Also word of caution make sure to check if your plug o ring is stuck to the pan on your first oil change.
Old May 21, 2017 | 02:38 PM
69cj's Avatar
69cj
2015's had two. One on each front axle shaft U-joint on the 4X4. None on the 4X2. I doubt if there was a change.
Old May 21, 2017 | 02:53 PM
MadeInDade's Avatar
MadeInDade
I thought I read that they were now sealed so there aren't any fittings anymore.
Old May 21, 2017 | 03:01 PM
PlatinumScorpion
I've seen both on past trucks good to know it's 2 or 0 though
Old May 21, 2017 | 03:57 PM
BII Plow Truck's Avatar
BII Plow Truck
Zerk = Hollow cavity for grease = less strength, more contamination possible.
Sealed no zerk = solid metal = strong, and less contamination.
Old May 21, 2017 | 04:06 PM
PlatinumScorpion
I agree I don't want them just trying to find out if we have any on the 17s?
Old May 21, 2017 | 04:26 PM
mlsjohn's Avatar
mlsjohn
One on each side of front axle joints.
Old May 21, 2017 | 05:05 PM
Louisville Joe's Avatar
Louisville Joe
Sadly no. Sealed ball joint = PLASTIC self-lubricating socket, likely worn out by 60,000 miles. Replace with an aftermarket Moog ball joint (with zerk fitting), never replace it again if periodically lubricated. There is no hollow cavity in a ball joint with a zerk fitting, just a couple of grooves in the socket which is metal (sintered iron, maybe a bronze alloy). Check the other Super Duty forums and see how many have issues with OEM non-greaseable ball joints.
Old May 21, 2017 | 05:35 PM
System's Avatar
System
Prolocutor
This^^. There are two zerks on the 17's.
Old May 21, 2017 | 05:38 PM
69cj's Avatar
69cj
I said it first, lol.
Old May 21, 2017 | 05:41 PM
System's Avatar
System
Prolocutor
Well, you said it with some uncertainty based on your 2015 experience...
Old May 21, 2017 | 06:30 PM
PlatinumScorpion
Thanks everyone
Old May 21, 2017 | 09:36 PM
Anthony W's Avatar
Anthony W
There are 8 total on the front end of the 2017 F450. Have not checked the rear end for some odd reason. I grease em every oil change, and I just did my third a few weeks back.
Old May 21, 2017 | 09:40 PM
2009kr's Avatar
2009kr
I bought a tube of the Motorcraft grease to make sure I use grease that is compatible with what Ford put in my F450.
BTW, my 2009 F150 doesn't have zerk fittings and the front end is still tight after 8 years and 145K miles.
Old May 21, 2017 | 11:42 PM
kry226's Avatar
kry226
My last truck was like this. It started with two from the factory. When I was done with it, it had eleven.
