Aerostar Ford Aerostar
Inside ventilation stops when engine pulling hard...
Old May 25, 2017 | 01:42 PM
DFord's Avatar
DFord
Hook the hand pump directly to the damper motor. When you pump it, you should see it's rod move. Once it moves as far as it can, you should be able to give it a couple more pumps and it should hold with no leak down.
Old May 25, 2017 | 04:58 PM
DarylJ's Avatar
DarylJ
Hopefully, it's as simple as the check valve, but if not, I have plenty of stuff to check, and now I know how to do it. Another thanks to everyone who has weighed in on this topic to help out with great suggestions on what could be at the root of the problem. There is no way I would have been able to find enough time to discover all the possibilities by myself. Forums like this are worth their weight in gold!
Old Jun 1, 2017 | 10:00 AM
Jose A.'s Avatar
Jose A.
you might try a cheap trick: a Cigar and smoke
watch this video: test vacuum leak with cigar - Bing video
Old Jun 1, 2017 | 06:25 PM
DarylJ's Avatar
DarylJ
.....and I just happen to have a big ole stogie waiting in the garage for a celebration. Looks like it will soon be up in smoke!
Old Jun 3, 2017 | 12:44 PM
Jose A.'s Avatar
Jose A.
well ? did you light it up?
Old Jun 3, 2017 | 07:37 PM
DarylJ's Avatar
DarylJ
No time yet. Hope to get on it again one day this coming week. Plate's been too full lately....
Old Jul 10, 2017 | 07:03 PM
asavage's Avatar
asavage
FTE Community Team
We've seen it all.
I've had two bad HVAC vacuum check valves over the years on my Aeros.
https://www.ford-trucks.com/forums/3...-controls.html
rvarc
1978 - 1996 Big Bronco
Aug 3, 2018 09:17 PM
Archuriel
Jul 28, 2013 03:28 PM
mustange70
Jul 12, 2012 06:46 AM
leardvr
Jun 18, 2011 11:39 PM
