Water Pump Question?
Old May 19, 2017 | 05:00 PM
woodsmoke's Avatar
woodsmoke
My 1953 still has the original 215 cid. A one year engine. My question is. Will the later 223 cid water pump fit? And. If so. What years? Thanks. Lee.
Old May 19, 2017 | 05:16 PM
52 USCG Panel's Avatar
52 USCG Panel
I just made a comment in another thread about finding a replacement water pump. Like you, I have a 215 cid engine. Mine is a 52, but I'm not sure if that matters. My water pump was leaking, and I took my truck to a local shop for a repair. They fixed me up with a new pump. I remember the repair was expensive, but there didn't seem to any special drama involved with locating a replacement pump. My old pump was not re-built. It was replaced.
Jim
Old May 20, 2017 | 06:03 AM
jvmcc's Avatar
jvmcc
My 53 215 water pump was leaking, so I replaced it with one from a 223. I had to have the original two-belt pulley pulled off the leaky pump and pushed onto the new one. Works fine.
Old May 20, 2017 | 06:15 AM
52 USCG Panel
That's an interesting bit of information, ivmcc. My replacement pump has a two-belt pulley. Maybe my repair included the pulley switch like you had to do and that accounted for the higher than expected charge. It wasn't mentioned at the time, however.
Jim
jvmcc
Jul 18, 2016 05:40 PM
nrogers130
Apr 6, 2015 06:49 PM
fakirone
16
Jan 3, 2015 04:59 PM
DAVID'S97F250HD
Oct 14, 2010 11:18 PM
