Hey guys, I did a quick search and didn't find an answer.
2011 F250 6.2L 4dig
I purchased the truck in February, and now that it is getting warmer here in MN, I am having trouble filling my fuel tank, E85 is less of a problem that regular fuel at times, but I can't even set the pump on the first notch, I have to flip the handle upside down and barely squeeze the trigger to fill the tank.
I assume the breather in the tank is the issue, is the valve fixable? Is it inside the tank or on top, I can see the little metal to rubber line but can't trace it back because of my melon.
Has anyone else had this issue? can I get a vacuum pump on the line to free up the valve if it's just sticky?
plz, help thx.
