1968 f250 new engine problems
Old Aug 19, 2017 | 04:57 PM
fe390pc's Avatar
fe390pc
Almost a guaranty that the "new" condenser is suspect. Do you have the original ford condenser. The other option is to change a petronix setup and eliminate the points and condenser completely!
Old Aug 19, 2017 | 05:10 PM
Ladybird48's Avatar
Ladybird48
response
I have a petronix kit ive tired on here that doesn't seem to work either. So I tried some other things like making sure the plugs where gaped properly and played with the timing some more. But I also tried spraying some carb cleaner down the carb and it seemed to sputter a bit. Even though the carb is definitely squirting fuel... So i pulled the carb off and put a Holley I had laying around that I built for someone who never came to pick it up and it sputters everytime now. So I played with carb adjustment some timing and It gets so close it might even run for a few seconds before dying. Eventually I got it to fire and I kept it alive by pedaling it but it sounded horrible not like a knock or anything just really lazy and groggy. I could even put the pedal to the floor and it wouldn't really rev it felt like mabye only a few cylinders where firing kinda shaky so I just turned it off and adjusted the timing and I got it better and kept adjusting and it was so close but the final time I adjusted it nothing. And when I set it back to where it was it does nothing now. I don't get it
Old Aug 21, 2017 | 11:17 AM
Ladybird48's Avatar
Ladybird48
update
So yesterday another buddy of mine took a crack at it. And we found that by advancing it alot it would fire up and run but it idols way too high because its way too advanced and when putting the light on it it reads about 20-25 can't quite tell but in that ballpark. If I attempt to retard it down anything below 20 it will start to die and even when put back up to 20 it dies same goes for adjusting the carb any idol adjustments and it dies. So I'm very confused by this. the chain was installed in the standard 0 setting. Its a edelbrock double roller set. Before when I had the truck running I had put the distributor in at 10 degrees and then retarded it down to 8 and it ran pretty good there. But this time I put it to 0 and it wont run unless its 20+. I had the old distributor in set in at 0 and adjusted to 8 and it ran good too till the gear pin sheared off. Any ideas?
Old Aug 22, 2017 | 02:26 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by Ladybird48
The distributor is an original but it has new points,condenser,rotor,cap,wires,plugs,and coil, the only thing I haven't changed is the ballast resistor for the coil. How can I test it? also how many volts should a coil see cranking and not cranking?
Did you buy a genuine Ford Motorcraft condenser? As I ststed, there has been a TON of bad AFTERMARKET condensers popping up here. INCLUDING brand new ones.
Take the wire off the "+" side of the coil. With the key ON there should be 6-8 volts at that wire. Cranking there should be 12.
Earl
15
Jan 18, 2010 04:28 PM
Singlespeeder
Nov 20, 2007 02:04 AM
wizzard351
Jun 30, 2007 10:18 AM
matt16875
28
Apr 9, 2007 11:51 PM
