Remote Start Access Error Code.
Old May 18, 2017 | 12:02 PM
motofreek77's Avatar
motofreek77
So I installed the Remote Access along with the VSS over the weekend and everything seemed to be working fine. But starting yesterday I would get an error code sometimes when I tried using the app from my phone. This is the code (00011000) i get when it doesn't work.
Have any of you that has the unit installed experienced this?
Old May 18, 2017 | 12:17 PM
alloro's Avatar
alloro
Pay particular attention to post #12 to see how he solved his issue with this code.
https://www.ford-trucks.com/forums/1...0011000-a.html
Old May 18, 2017 | 01:00 PM
motofreek77
I checked all the connections and everythings good. Can i unplug everything and plug it back in without needing a new pin from dealer?
Old May 18, 2017 | 02:30 PM
bridge's Avatar
bridge
Sick 'n Tired
I get this error when I don't have good cell signal. Looking at your pic you've only got 2 bars, so the RMU probably has no bars. Where did you put the RMU, up under the dash per the instructions? You really have to have a good high strength signal for it to work up under the dash. I put my RMU in the drivers side a pillar. It helps a bit placing it higher up.
Also, I heard that this system uses the AT&T network, so if you're in an area that is known to be an AT&T deadzone it won't work. I live in such a zone so mine doesn't often work while parked in my driveway.
Old May 18, 2017 | 02:39 PM
motofreek77
That's interesting. I just followed the instructions and mounted the RMU under the dash. I think I might try your solution since it makes sense that it may have a harder time receiving a good signal down there. Do you know if the RMU responds if my phone is connected to WIFI?
Old May 18, 2017 | 03:06 PM
bridge's Avatar
bridge
Sick 'n Tired
Depends. If your phone has "wifi calling", i.e. it uses the wifi network for calls (which means it uses the wifi signal to route the call to the cell network) it should work. But if you're just on wifi with no call or messaging support then it won't work.
Old Nov 8, 2017 | 12:12 PM
zjbowman's Avatar
zjbowman
Same truck, same issue
I have the same truck, with the same issue. Installed the VSS, and the RMU, and added the subscription. I receive alarm trigger alerts, and the app will tell me if the truck has gone to sleep, but I cant get the sent commands to work. I receive the same error message each time. The dealer that sold me this said some of the 17 SDs have this issue and others don't. After over a month of reading forums, I seem no closer to having this work. There must be someone who has this figured out!? By the way, mine has NEVER worked for me.
Roody727
Jun 20, 2017 06:59 AM
madsonp
6.7L Power Stroke Diesel
15
Dec 2, 2014 05:04 PM
rch10007
Electrical Systems/Wiring
13
Oct 26, 2013 10:05 PM
rch10007
Sep 29, 2013 08:13 PM
96f150
Apr 14, 2011 02:15 PM
