Back up sensors
Old May 18, 2017 | 01:00 AM
1911fan's Avatar
1911fan
Back up sensors
Is there a way to turn off the alarm for when my tailgate is down or my hitch is in without the trailer hooked up?
Old May 18, 2017 | 11:17 AM
swarf_rat's Avatar
swarf_rat
After extensive experimentation, the only way I have found is to put a 100 ohm 5W resistor between the brake control line and ground. You can do this inside a dummy plug plugged into the trailer 7 pin. You also have to set the brake control to electric over hydraulic in the dash settings.
The system shuts off the backup assist when it senses a trailer brake connected. That is either a very low resistance (with electric brakes) or a higher resistance (with EOH brakes). 100 ohms sinks enough current to fool the EOH, hard to sink enough to fool the electric without a very large resistor (100W 5 ohms or so). Some have just plugged in a spare electric brake coil (effectively a very large resistor).
I put the 100 ohm inside my slide in camper connector, otherwise it complains continuously anytime I select reverse.
Old May 18, 2017 | 01:56 PM
djousma's Avatar
djousma
If you have the productivity screen, there is an option to turn it off for that occurance only while in reverse. Or you can go in and turn it off permanently.
Old May 18, 2017 | 03:09 PM
System's Avatar
System
Prolocutor
I wish you could turn it off permanently Dave but you can't. If you shut it off it will be back on the next time you start your truck.
Old May 18, 2017 | 03:10 PM
PlayersZ28's Avatar
PlayersZ28
I can turn mine off for the current reverse but not permanent from what I've found. I'd like to turn them off as they are POS's and I have 2 failed ones. I had 4 replaced under warranty.
Old May 18, 2017 | 03:14 PM
System's Avatar
System
Prolocutor
This would be a cool project for the Forscan experts. I'm sure it could be changed to make it so when you change the setting in the MFD that is stays.
Old May 18, 2017 | 03:24 PM
djousma's Avatar
djousma
I know you can turn it off when in reverse for that time. And as it turns out, the option in driver settings is also temporary, which I though would have been permanent...
Old May 18, 2017 | 03:28 PM
System's Avatar
System
Prolocutor
That's the one I'd like to see Forscan help with Dave.
Old May 20, 2017 | 05:52 AM
Deuce40s's Avatar
Deuce40s
You would think....
I've been searching all week how to disable it permanently. What I don't understand is I can turn off my seat belt minder permanently, but not the backup alarm.
Old May 20, 2017 | 12:46 PM
Nipperdog's Avatar
Nipperdog
I know that it's a PITA when towing, but I wouldn't Premanently Disable it.
It has saved my Butt many times and continues to do so. It is especially useful in large Parking Lots when you're backing out of a space, and some Moron decides to walk right behind you
Old May 20, 2017 | 11:21 PM
swarf_rat's Avatar
swarf_rat
When you turn it off via the "productivity" screen, it is off until the next key cycle. Then it comes back on again. Unless you make the plug I suggested above. Then it is off until you unplug the plug.
Old May 21, 2017 | 09:25 PM
1911fan's Avatar
1911fan
Guess i will just live with it.
WDESIGN
Apr 17, 2018 06:49 AM
elkarcher1716
2009 - 2014 F150
13
May 15, 2014 09:17 PM
GGWild
13
Jul 28, 2013 05:23 PM
Medic 66
Sep 19, 2012 04:53 PM
RussF350
Mar 27, 2010 10:29 PM
