Aerostar Ford Aerostar
Valve cover gaskets
Old Mar 13, 2008 | 02:40 PM
Bear River's Avatar
Bear River
Former ******
Valve cover gaskets
My engine does not burn any oil, however, it has developed a considerable external oil leak that I am confident is from the valve cover gaskets. It developed just after my van caught fire (due to a transmission fluid leak onto the hot exhaust). I can not see exactly where it is coming from, but it is from higher up on the block. Everything else is good. So my main quest is the recomended procedure for replacing the gaskets, any tips or tricks to make it faster or easier, and any recommended brands or parts
I was looking at these gaskets
Fel-Pro #VS50368T PermaDry
These as best I can tell are not cork gaskets. If anyone has any advise on these I would be interested in hearing it.
The van does not have any coolant leaks that I can tell (only have to add a few cups of coolant every 15,000 miles or so, mostly boil off is my guess)
Any other things you guy recommend replacing while doing the valve cover gaskets?
Old Mar 13, 2008 | 03:37 PM
Pablo-UA's Avatar
Pablo-UA
Not sure about cologne, but when 3.0 valve cover gaskets start leaking, no reason to change because....
Just changed valve cover gaskets, got intake manyfold oil leak, in distributor area. Did it too (had to remove valve cover gaskets, and replace them), later I got oil leak from front engine cover (water pump is bolted on it).
But it was not all. got oil pan gasket leak.....
but it was not all!!!!! Crank seals!!!!
Conclusion.
To replace all gaskets, seals, ready to leak I you have to put nearly all engine appart. But If you have engine with removed heads and front cover it is less then a hour to replacepiston rings and bearings.
So I advice you to retorq all, and wait for major problem adding a quart of oil every 2 mounth. Getting real engine troubles, rebuild it (not difficult really. I did it) and forget about engine for next 10 years. Use good parts. Nothing chineeze.
Old Mar 13, 2008 | 08:10 PM
93nighthawk's Avatar
93nighthawk
I would go with Ford OEM Steel gaskets, I believe those Felpro's are quark, which will leak again in no time. While you are at it, you will want to get the intake gasket set, sense you have to remove the whole intake to get the valve cover gaskets off on the 4.0LAnd while you are at it, might as well pull the heads off, get them checked, and replace the head gaskets.
Old Mar 13, 2008 | 08:55 PM
aerocolorado's Avatar
aerocolorado
The condition of the valve covers is often of more importance than the type of gasket. If your's have never been off before, then you are ahead of the game. If they have been worked on, it is rather common to overtorque the hold down bolts and thus distort the critical sealing surfaces of the cover. There should be no dimpling or bowing around the bolt holes.
Be sure to also note how and where the "dog ears" are positioned around the cover. Replace them the same way. They serve to distribute torque over a wider area and prevent "dimpling" when tightening the cover. The torque specs are not all that high, but stick with the recommend values.
I replaced mine last year with the FelPro cork style (not my choice, they came in a head set) and have not had any problems thus far.
Old Mar 14, 2008 | 08:56 AM
Bear River's Avatar
Bear River
Former ******
Why would I need to check the heads? Never overheated the engine or let it run low on coolant. I'm not loosing coolant, and my engine is burning perfectly clean. I don't see a point in doing a head gasket unless I need a head gasket. The part number I linked was the only one not described as cork. It didn't say what they were however.
I will go ahead and get the intake gaskets. As I mentioned, I didn't have the valve cover leak until after the fire, so it probably caused the gaskets to vulcanize and harden.
Old Mar 14, 2008 | 11:12 AM
Pablo-UA's Avatar
Pablo-UA
Problem may be in covers, not heads. My covers were bent a bit and the only way to prevent leak was RTV ore other sealant.
Old Mar 14, 2008 | 03:33 PM
Bear River's Avatar
Bear River
Former ******
Which leads me to a related question. Do you use sealant on the gaskets or not? And if you do, is there a proper procedure? I want to fix this leak for as long as possible.
Old Mar 14, 2008 | 04:10 PM
copper_90680's Avatar
copper_90680
As far as I can tell, the rubber gasket (with steel or plastic backing) needs no sealant except for the location where the intake manifold meets the head. You need a small bead of RTV there. The cork gaskets are a different story, I simply shy away from those.
Old Mar 14, 2008 | 04:57 PM
Pablo-UA's Avatar
Pablo-UA
I had small Ukrainian Tavria with made af alluminium head and head cover. Overheated ones she started leaking oil from under the valve cover. I tried to replace gasket, resurface cover, upper head surface, but I sold her with dirty head. No, she did not birn oil, I added not more 2 quarts per year, but I had to replace spark plugs in glowes to keep hands clean.
Old Mar 14, 2008 | 06:17 PM
96_4wdr's Avatar
96_4wdr
i like the old school liquid thick Permatex Super 300 paint on and let her tack up. use it on everything but my morning toast.
my problem is remembering to clean the cap threads and then trying to get the can open 3 months later
but seems like everyone is going to the hi. tech. hi temp O2 safe automotive rated RTVs in a tube. my favorite of those is Permatex's Right Stuff, but has the wrong price
Permatex's web site has a breakdown of all their sealant, goop, liquid gasket materials. what applications and how to apply
nothing leaks like an old Ford Y block 312 with cork valve cover gaskets. the main seals leak from first mile on road
kb1jid
Dec 12, 2011 09:33 AM
kb1jid
Dec 11, 2011 07:05 PM
JoeVR5
1983 - 2012 Ranger & B-Series
Aug 9, 2011 09:07 AM
1998Ranger25L153CID
Jan 1, 2009 06:39 PM
1954blueoval
Aug 1, 2005 03:08 PM
