1978 - 1996 Big Bronco
Broken spark plug
Old Feb 16, 2003 | 03:47 PM
dassmoof's Avatar
dassmoof
Angry Broken spark plug
So my rachet got stuck while trying to remove a spark plug. Eventually I got it out, but it cost me incredibly dearly.
It broke the sparkplug in half. Now I've got half a spark plug stuck in my cylinder. I'm so incredibly pissed off you don't understand. Is there anything I can do besides spending a few thousand dollars at a shop to get it out?
Old Feb 16, 2003 | 04:09 PM
speed1972's Avatar
speed1972
Broken spark plug
where did it break? should still have something to grab a hold of with a socket....
Old Feb 16, 2003 | 04:29 PM
alanscott's Avatar
alanscott
Broken spark plug
Did you fumble the top half and fell back into the hole?
It's usually the ceramic that breaks but the threads and "Bolt" head are still removed in the same manner.
Old Feb 16, 2003 | 05:07 PM
dassmoof's Avatar
dassmoof
Broken spark plug
Yeah, I just got it out, thankfully. It was the ceramic part that broke. I thought I was totally screwed at that point.
One more thing. I finished replacing the drivers side plugs, but I can't get any of the passenger side out. It's way too cramped and they're pretty well stuck in there. W/o much room to move it's going to be impossible to get them out. Would it hurt to put WD-40 on them? Also whats the best way to get around the small space?
Old Feb 16, 2003 | 08:08 PM
msuforeman's Avatar
msuforeman
Broken spark plug
Try jacking up the front of the truck but not far enough where the tires are off the ground. Go through the plastic on the passenger side fender well. The plastic piece comes out pretty easy. I've used wd-40 a few times on different vehicles and have not had a problem.
Good Luck,
Brian
Old Feb 16, 2003 | 09:42 PM
speed1972's Avatar
speed1972
Broken spark plug
try PB Blaster.. that stuff is the greatest nut buster ever made.... It works on just about anything and is 10 times better than WD-40...Larry
Old Feb 16, 2003 | 09:54 PM
msuforeman's Avatar
msuforeman
Broken spark plug
TRUE--Wd-40 sucks compared to that stuff
