Hey guys, i took my truck for the first test drive today and got a little ways down the road. My front brakes were completely stuck on, i opened the bleeder on the driver side to relieve the pressure and made it back home. It was stuck so bad the truck wouldn't move. I did hold the pin in on the P valve while bleeding the front, im wondering if i didn't have it pushed in enough. Any suggestion where i should start looking first?
-New master cyl
-new calipers
-new hard lines and hoses
hmm, it is a new booster as well. forgot to mention that. i read in another thread, a guy had the same problem and it was the brake switch on the pedal was turned out too much and wasn't allowing the pedal to come back out all the way. i'm going to check that after work.
but hopefully i get some more ideas where to look.
If your rubber brake hoses are old and showing cracks in the rubber, then they could be causing a check-valve action.
Master cylinder is strong enough to push fluid into the caliper, but the caliper retracting is not strong enough to force it back to the master cylinder, causing the brakes to stick.
As I just mistakenly posted in the other brake thread: I was just reading a brake fluid discussion on my Corolla's forum, and a guy there said that he has had some brake hoses swell shut after switching to DOT4 fluid.
And another possibility is the metal retaining bracket, if there is one. They're usually bent to curl around the hose. But if they're too tight, they will cause the check-valve effect as well. Real common on the Tempo and Topaz. I fixed several of them by simply using a flat-blade screwdriver to spread the curl, so as to increase its diameter and let up on that hose!
just to confirm i'm understanding this correctly.
Between the brake switch adjustment and the booster rod. I should have 15/16" from master mount plate to the tip of the rod, with the pedal in nutrual position? Meaning if i set the switch first and then ajust the rod length to accomadate the how much the switch pushes it out further.
and also is that length the same for all of these trucks?
mines a 79 f250
Another vote for the power booster. Just replaced my booster and master cylinder (came as one unit). While diagnosing neither front wheel would free wheel when raised. Thought I also had a caliper problem. After replacement of booster and master cylinder they now free wheel just fine. I did read that the intake manifold port where the vacuum hose connects can muck up with carbon, esp if you are running a rich mixture. I checked my and found no problem. Give it a look.
mines a 79 f250
My truck is a 79f250. If the brake assembly is mix matched like pedals and booster bracket from different years. You will never get the rod adjusted correctly. If the pin is out of adjustment the brakes will work for a few minutes then they will start to lock up.
mines a 79 f250
Unbolt the brake fluid reservoir. Leave the lines attached pull it back a little.I put a broom stick under it and put the stick across the inner fender to the valve cover to hold up the resivoir . Then it's 15/16 from the tip of the rod to the face of the booster.
that is the case for me, my cab and pedal is from a 77 and the booster/master cyl is from a 74.
your saying it's tough to get it ajusted correctly? can't i just set it too the 15/16" and i'll be on my way?
Yup. I can gerrantee mixed parts are the problem. U have to find the parts as a set for. A 79. I had to buy a whole junk 79 f250 for the parts . Don't bother trying parts to match yours. Just get all the parts from the same parts truck the 79 pedal has a particular part number on it. But I forget the number . Good luck. If u must drive the truck carry thec9/16 wrench and broom stick with u.
