Rear Tank Install Going Rough!
Old May 16, 2017 | 09:04 PM
TobaccoBarn460's Avatar
TobaccoBarn460
Had to put a rear tank in my '89 F-350.
What makes this job a bad one is the tank is boxed-in between the frame rails on the sides, and cross rails directly behind the tank and in front.
The fuel lines run ABOVE the forward cross-rail rail, below the bed.
The tank has to DROP to be removed.
The steel nipples of the fuel pump set the direction of the fuel lines.
The return fuel line does not face the side rail that the fuel lines are run on, so there's a 90 degree connector that allows the tank to drop.
But the supply line faces that rail.
So the factory uses a straight connector, and I cannot see how anyone could drop that tank (with that line above that cross rail), without breaking that supply line fitting (which I obviously did).
The factory obviously assembled this with the bed off.
So after installing a repair barbed coupling on a Dorman repair straight connector, it's impossible, so far, to snap that straight connector on that tank with what little room is available, as it's peeking out from behind that cross-rail.
My other option is cut off a section of fuel line with straight connector, snap it onto the fuel pump nipple, put it up, letting the cut fuel line tail poke through the opening at the top of the cross-rail, then make an annoying barbed connector connection up near the bottom of the bed.
I'd be real interested in any suggestions.
Old May 16, 2017 | 10:26 PM
rla2005's Avatar
rla2005
I dropped the rear tank on my 1992 F350 with two ratchet straps and very little drama. The most difficult part was getting the fuel lines loose. My fancy metal disconnect tools were worthless. I ended up buying some cheap plastic release tools.
Old May 17, 2017 | 07:35 AM
'89F2urd's Avatar
'89F2urd
The rear tank is a wh0re, no doubt, but I've always drained the tank and gotten to the lines by dropping the straps and tilting the front of the tank down enough to snake my arm up there to remove the lines. I've never had an issue this way.
Old May 17, 2017 | 07:40 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try unclipping the feed and return lines from the crossmember and up the drivers side frame rail to the selector valve.
Now you should have enough slack to attach them and get the tank back in.
My '87 is a real PITA because of the receiver hitch bolted on both sides.
Old May 17, 2017 | 12:28 PM
Brian Ski 44's Avatar
Brian Ski 44
Yea... I hard to take the receiver off to get the tank to clear.
Old May 18, 2017 | 05:05 PM
Benztechnc's Avatar
Benztechnc
I snaked mine past the receiver, but I already had the bed off which made it MUCH easier.
Old May 18, 2017 | 05:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I didn't need to remove the receiver to change the tank or to replace the rear shackle hangers, but it did make it challenging at times.
kevin206
Sep 10, 2014 08:36 PM
BigBlue92
Sep 7, 2011 10:20 PM
custom_nirvana
Jan 27, 2011 10:30 PM
newtattoobob1
Oct 21, 2009 08:01 PM
Frdbuy8589
May 4, 2009 12:54 AM
