bbk throttle body?
Old Sep 3, 2003 | 10:14 AM
panteramatt's Avatar
panteramatt
bbk throttle body?
Are these worth the $ for the 5.0 and if so which size the 56mm or 61mm?
Old Sep 3, 2003 | 01:43 PM
Kemicalburns's Avatar
Kemicalburns
bbk throttle body?
56 will bolt up stock. the 61 will require some porting of the intake to match up.
late
Old Sep 3, 2003 | 04:21 PM
panteramatt
bbk throttle body?
are they worth the $ and will I feel a difference?Anyone have one?
Old Sep 3, 2003 | 04:36 PM
Kemicalburns
bbk throttle body?
i have heard good things about them, wouldnt be a major change. What other mods are on this motor. if you have headers and a good exhaust i would say you would see a good increase in power. You might have this topic moved to the bronco or truck forum you will get more feedback there.
later
Old Sep 28, 2003 | 09:42 AM
true4.2's Avatar
true4.2
I've heard a BBK Throttle Body for a 5.0 can bolt up about 12-15 hp's alone. Add a spacer and an intake, and I'll bet money you'll be pushing around 30 extra hp's. I've actually seen dyno tested and proven results with this mod on the V6. The V6 alone gained 28 hp. Gains for a 5.0 would be even greater.
Old Sep 28, 2003 | 09:38 PM
fordeverpower's Avatar
fordeverpower
no way, its like $180 for like little gain. Get a kn filter if anything or get the 75mm outfit amd makeit worthwhile.
Old Sep 29, 2003 | 09:27 AM
Kemicalburns
the mustang and truck throttle bodys are different . so a 75mm wont work. The throttle body spacers are a joke, they hardly show any gains. unless your throttle body is messed up I would just clean it up good and run it till you get some other mods on your rig otherwise you wont notice a whole lot of grunt.
later
Old Sep 29, 2003 | 12:15 PM
panteramatt
Yea, Im getting a FULL exhaust put on, filter, and pullys.I think Ill wait on th ethrottle body until I get better heads and cam.
Old Sep 29, 2003 | 12:52 PM
Kemicalburns
What are you driving panteramatt. i would not suggest spending money on the pullies if you drive a 4x4. because the underdrive will cause the alt to not spin fast enough to produce the right amount of charge for you battery if you have a lot of accessories like off road lights, stereo and so on. plus it really doesn add that much power.
latr
Old Sep 29, 2003 | 01:10 PM
panteramatt
I drive a 93 ext cab 4x4, and yes it will have a new stereo system.Im going to get an overdrive pulley for the alternator when I get my pulleys and I already have a optima battery.
Old Sep 29, 2003 | 09:41 PM
Hit Man X's Avatar
Hit Man X
Good idea there, the BBK Twin 56mm is just over $300. Unless you have good heads (nothing factory or factory ported) and a nice cam you may gain 2-4rwhp top. The motor simply can not pull that much air into it.
The stock 302/351W TB is just over 49mm. It flows enough for easily 275rwhp.
No single part (well other than heads) will add more than 8-15rwhp at a time. These are all slight power gains. Unless you do one huge step at a time (like Matt's going to full exhuast) you will not notice much gains of small things. The overall is where it helps. I have every bolt on except electric fans (waiting to upgrade alt to a 200A unit) and my truck will run circles around all stock F-150's of the same vintage.
Ad claims are TOTALLY different than real world power levels. I have been there and done that.
Old Sep 29, 2003 | 10:19 PM
pfogle's Avatar
pfogle
The TB on my 351 is alot bigger than the one on my dads 302........ Not a little bit gigger but like almost 10 millimeters bigger.
Old Sep 29, 2003 | 10:21 PM
Hit Man X's Avatar
Hit Man X
I remember posting up that your van's 351W also has red top injectors that are 30lbs/hr...I don't think that it is stock with that large of a TB but may be.
I measured mine and got just under 50mm
Old Sep 30, 2003 | 12:28 PM
panteramatt
yea I need to get rid of these crappy heads!
Old Oct 1, 2003 | 01:37 PM
pfogle's Avatar
pfogle
Not sure.... I do know that it was the tow rig for dirt track racing team at one time... Looked like for about the first 3 years of it's life...
