Stage 1 vs. Stage 2
Old May 15, 2017 | 10:14 AM
RhinoRidener7's Avatar
RhinoRidener7
Stage 1 vs. Stage 2
Needing to replace the injectors in my truck, was thing of going with stage 2 injectors but I'm not sure if they are too much for my truck. My main concern is EGT and power, I do a lot of hauling with my truck I plan on upgrading the turbo in the future for sure. But I also don't want to get stage 1 and then want stage 2 later down the line. Any help would be much appreciated
1995 7.3l
Mods:
TS-6 Pos
3 inch down to 5 inch straight
S&B Cold Air Intake
Wicked Wheel II (stock turbo)
Glow shift Fuel pressure, Pyro, Boost
Old May 15, 2017 | 10:17 AM
cowmilker08's Avatar
cowmilker08
What transmission?
What power goals?
What use?
Elevation?
What is your planned turbo upgrade?
Old May 15, 2017 | 10:22 AM
RhinoRidener7
Originally Posted by cowmilker08
What transmission?
What power goals?
What use?
Elevation?
ZF-5 5 speed
I don't plan on making a lot of power just around 400ish
I use the truck as a daily as well as pulling trailers hauling cattle, hay, etc.
I've heard that the KC38r is a good upgrade
My elevation is about 2,300 ft above sea level
RhinoRidener7
What transmission?
What power goals?
What use?
Elevation?
ZF-5 5 speed
Old May 15, 2017 | 12:19 PM
oldbird1965's Avatar
oldbird1965
You can see what I haul, 20K. With stage ll's I was always backing out of it because of EGT's. I had them converted to stage I's and am much happier. I still have EGT problems but what can I expect going across county with that load?
Old May 15, 2017 | 03:16 PM
BBslider001's Avatar
BBslider001
What Glenn said. If your truck is a dedicated hauler, stay away from Stage 2 unless you plan on dropping a LOT of coin. I had Stage 1 in my 97 in my sig. It had plenty of power to haul 11k with power to spare.
Old May 15, 2017 | 06:57 PM
fordman67's Avatar
fordman67
The only way it would be a good idea to do stage 2's is if you upgrade turbo. A correctly sized t-4 unit would tow fine. I know of a build that will have stage 2's and big air. I believe it will be a beast of a towing machine. I can't wait to get the data after its done on how it performs. I tow just great with decent size stixs but I'm not on any semblence of anything stock turbo related. If you think any drop in charger is going to support 2's then I think you will be disappointed.
Old May 16, 2017 | 10:29 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The smaller the nozzle, the easier it is to tune for towing. Period
If you plan on towing a lot, then go with the Stage-1's and be happy at 325 hp. You'll hate the Stage-2's.
On the other hand, if you have the ability to get your truck LIVE tuned by one of the 4 or 5 good tuners in the country, then you can go with a larger injector, take the truck and a loaded trailer to them for some good live tuning, then you can do what you want.
Otherwise they are taking a best guess as to what will make your truck run well (not a knock to the tuning guys, that's just how it is) because every truck responds differently to tuning and you'll never like towing with the Stage-2's.
I've run all different sizes and kinds of turbos and nothing towed well until I had my truck live tuned.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old May 16, 2017 | 10:33 AM
oldbird1965
Who are these 4 or 5 LIVE tuners Jim?
Old May 16, 2017 | 11:20 AM
BBslider001
Annnnd like I said, plan on dropping A LOT of coin to be happy with Stage 2s...JMO.
I towed my horse trailers and my travel trailers MANY miles with Stage 1s, an Intercooler, STOCK turbo, and tuned. 30 pounds of boost and hauling up a 6% grade at 65 mph was plenty good for me. I am not sure what more someone wants out of a diesel truck. 70 mph? 75 mph? Anyways, I was very happy with performance. I had no EGT issues and power to spare with 11k pounds.
It just gets into "want" vs. "need". If you "want" it, spend away with your time and money, because it takes a lot of both to get it right. If you are talking "need", Stage 1s will serve you well.
Old May 16, 2017 | 11:31 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Without an air-to-air, don't do anything to it. Stock injectors with tuning can exceed safe limits on EGT. Once that is on the list, you can get away with a little more but you're not going to put 400 horsepower through it while towing for very long until the rest of the drive line melts down.
Old May 17, 2017 | 10:29 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Any of the popular name tuners can do Live tuning: PHP, DP Tuner, DynoProven, PowerStruck, Gearhead, Swamps, Innovative, etc. (Ok, there are more than 4 or 5, but I personally only like 4 or 5 of the ones I listed. )
Very, very true, and good point.
However...I had 238/200% Hybrids with a 38R that Bill LIVE tuned for me way back when, in my '96 that has never had an inter-cooler, and that truck towed great! But only after live tuning.
__________________
Old May 17, 2017 | 10:58 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Jim,
And what about between stage 1 vs. 1.5
Old May 18, 2017 | 02:11 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by RÖENTGEEP
Jim,
The 160/30% Stage-1.5 have been growing every year, and I think we might be building more of those than Stage-1's now. They are a good in between injector and a good compromise vs the Stage-2's.
But it really comes down to what other mods you have. If the truck is pretty much all stock, the Stage-1's do great. But if you have a larger turbo, HPOP, fuel system, intercooler, AND you tow, then the 160/30% Stage-1.5's will be a better choice than the 160/80% Stage-2's. The 160/30% also can be more easily (but maybe not perfectly) tuned back if you think you want to upgrade all of this stuff and want a little more power later on, which is why they are kicking Stage-1's from the top spot.
If you want safe safe safe across the board you can't loose with Stage-1's.
__________________
Old May 19, 2017 | 09:03 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Perfect thats what I wanted no know
Sous
2133
May 12, 2021 04:33 PM
spdmpo
91
Feb 23, 2011 03:22 PM
suzuki_vinson
Oct 19, 2007 11:16 AM
Dustball8504
Sep 8, 2007 08:51 AM
97REDPSD
Apr 10, 2007 04:07 PM
