Sponsored by: Real Truck
Difference between pre march 99 and post march 99 4X4
Old Sep 3, 2003 | 09:37 AM
Justwingem's Avatar
Justwingem
Anyone know the difference between the pre March 99 and post March 99? I am about to put a 6" lift on my F350 PSD Ext cab and was curious about the difference?
Old Sep 3, 2003 | 12:43 PM
tankhead's Avatar
tankhead
I think the u-bolts are one of the easiest ways to determine pre and post march 99. I have an early 99 and mine are square.
Old Sep 3, 2003 | 02:13 PM
RRMike's Avatar
RRMike
the track bar bracket is different and so is the pitman arm. If you get the wrong kit these as well as the u-bolts as tank mentioned will be wrong.
Old Sep 3, 2003 | 02:36 PM
Justwingem's Avatar
Justwingem
Thanks for the info.
I am also finding something different in the air intake area as I have been looking at various upgrades for it as well. Any ideas?
Old Sep 3, 2003 | 02:55 PM
tankhead's Avatar
tankhead
I think that's towards the end of 98 when they changed the inlet from the wheelwell to the grill like the V-10's.
Old Sep 3, 2003 | 09:02 PM
99f350sd's Avatar
99f350sd
Mine is a 3/3/98 the airbox opening is behind the grill. The track rod is different so is the hole in the axle and the hole in the bracket as well as the bolts. You can buy a new bracket but the axle hole will have to be drilled 3/4 If I remember correctly..
Old Sep 3, 2003 | 09:08 PM
DCSpecial's Avatar
DCSpecial
A buddy of mine had an early '99 PSD as his service truck at work and they had a problem with it sucking water into the intake and soaking the filter when they would drive it on the highway and it was raining.
If you wanted to upgrade to an AFE there are some shops that sell the combination '99.5+ aibox and AFE that as a package deal saves about $75.00 over buying them individually.
Hope this helps.
horseman54
Feb 28, 2015 08:23 PM
PMDRACER
Jul 5, 2013 10:50 AM
splice1985
Jun 8, 2012 01:11 AM
mizzitch
Oct 17, 2011 05:10 PM
savage2211
Delaware Chapter
48
Mar 11, 2007 02:05 PM
