Computer Chips & Tuners
TS Performance 6 position with PCM
Old May 14, 2017 | 01:36 PM
Hoffcos's Avatar
Hoffcos
My PCM is UKN0 and it is in an F350 Dually with 4WD. I read that the pcm is for an excursion. Would this be an issue with performance in the truck with it stock? I have the TS performance tuner but stopped the install when I came across this issue. The tuner says it's for my year and engine but im unsure about the pcm. Should I change the pcm to match the truck? I've contacted the TS Performance to check and awaiting response on the chips compatibility with the pcm. Any suggestions from y'all will be much appreciated.
Old May 20, 2017 | 10:44 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
California model 00?
If so, you're fine.
Bonanza35
32
Jan 24, 2012 06:34 PM
Krazymaan
Aug 24, 2011 06:53 AM
paradiseandpalms
Sep 13, 2006 02:39 PM
Okgunslinger
17
Sep 17, 2005 05:18 PM
Kurious
2004 - 2008 F150
Jul 31, 2005 12:36 PM
