New-to-me 2001 F-250 7.3
Found a 2001 Ford F-250 Super Duty Crew Cab, 4x4, Lariat, 7.3L with 105k miles on Autotrader in Mississippi for $12,958. Called them up and they had just traded it from an elderly couple who used it to tow their fifth wheel. One owner, clean Carfax (attached), regular maintenance ALL documented on the Carfax. He was trading it because he wanted the 6.7. I thought it sounded too good to be true so I had the salesman send videos of it running, asked him to send one of setting the oil cap on the oil filler tube to check for blow-by, etc. Everything seemed to check out. Only thing I could think of at this point was a bad tranny. So I asked him how it shifted. Of course he said fine, so I took his word. I was still hesitant, but figured what could I lose; a 7.3 with 105k miles for 12k? So I put $500 down and told him I'd be there in two days. Got on Southwest and bought a "wanna get away" ticket to fly down Friday (this was Wednesday) and take a look. Got to the dealership, asked him to start it up while I checked for blue smoke...no blue smoke. Listened for knocks...no knocks...verified speedometer worked (thought maybe that's why it had such low miles?) but it worked...took it for a test drive, shifted fine, looked for leaks, no leaks. Pretty much flawless for a 2001. Could not find anything wrong with it. Went inside and sat down with the finance lady. Half an hour later I walked out with the keys and drove it 700 miles home to North Carolina, ran perfectly the whole way.
Thanks, I was pretty happy with my find.
Diff fluid yeah, says in the Carfax, not sure about the trans fluid but it was bright red so possibly? From the Carfax it appears this guy was super **** about maintenance, so I'd hope so.
I honestly hope that the dealer threw in $5k or so in services!! Yikes $12k seems a tad high granted it's in superb condition, so I'm hoping that's part of it, but you may want to check all fluids to make sure they were changed, if it's an E 99 (fender badge) it will use the regular green coolant with SCT additives (i think that what it's called) if it is a L99 (I think that is when the switch was done, please correct me if wrong) it will use an OAT and IIRC Motorcraft gold.
also nice find hope it can make breakfast and bring it to you in bed too
According to AutoTrader:
Price Range of Results: Highest: $25,000 | Lowest: $13,975 | Average: $20,311
its an 01, not e99.
Some would turn over in their graves knowing what I paid for mine and I thought it was on the low end of what I was seeing out there for the condition and mileage I was being picky about. Going rate is also dependent on location, but glad you were able to cash in on the deal. I can only imagine how nerve-wrecking the flight over was for you.
its an 01, not e99.
