Adaptive stearing regrets?
Old May 14, 2017 | 06:02 AM
RJC2's Avatar
RJC2
Originally Posted by Ricohman
If you ever drive down some greasy slick hills with wet grass you will appreciate the descent control.
It will be on my 2018.
I think that decent control is a total waste of money. I'd be willing to bet that 99% of the trucks that have it, have never used it once. I don't know anyone who has.
Something tells me I'm about to though...
Old May 14, 2017 | 04:39 PM
troverman's Avatar
troverman
I have no regrets on the adaptive steering...I didn't order it. Truck steers fine. As to the comment about a dump truck...well, if you bought a 350 with adaptive steering and put a dump body on it...it also would drive like a dump truck.
Hill Descent is useless for almost all users. Low range and manually selected gear + locked rear end gives you the same level of control but without burning up the brakes.
Old May 14, 2017 | 06:19 PM
Chris Crews's Avatar
Chris Crews
So the adaptive steering just reduces the amount of turns you use to steer the truck?
it still has normal
power steering?
Old May 14, 2017 | 06:54 PM
K2500Z71's Avatar
K2500Z71
it still has normal
power steering?
Still has normal power steering. The adaptive steering unit is an electric motor in the steering wheel that multiplies the number of turns that the steering shaft actually turns depending on your speed. It basically sits between the steering wheel and steering shaft and takes input from the steering wheel.
Old May 14, 2017 | 07:34 PM
kab449's Avatar
kab449
Makes it easier when backing a trailer into a tight spot. Steering wheels react quicker to your input. I like it and would get it again. I have a 37' fifth wheel I pull.
Old May 14, 2017 | 10:25 PM
RJC2's Avatar
RJC2
It also works in the inverse way at highway speeds by making the steering wheel move more turns for the same amount of steering.
Old May 15, 2017 | 05:57 AM
Benny996's Avatar
Benny996
I agree with kab449, it was so much easier backing my 40' 5er into the camp site this weekend. I guess I hadn't even thought about it being the adaptive steering, my 2011 F350 turned slower than an aircraft carrier. I looked like I knew what I was doing! I also just got the skid plates and locking diff, no FX4 package.
Old May 15, 2017 | 08:35 AM
shortride's Avatar
shortride
I'm still a little bit old school. If "adaptive steering" is the option that has to do with backing a trailer then I would suggest not getting that option. Like a lot of other things these days, if we have forgotten how to back a trailer we had better stay home.
Old May 15, 2017 | 08:52 AM
troverman's Avatar
troverman
Originally Posted by shortride
I'm still a little old school. If "adaptive steering" is the option that has to do with backing a trailer then I would suggest not getting that option. Like a lot of other things these days, if we have forgotten how to back a trailer we had better stay home.
It really is not a bad thing, and you won't lose any trailer-backing skills with it. It just changes the steering ratio to a quicker ratio at low speeds and a slower ratio at high speeds.
I didn't want it simply because I don't see any great value with it. I have no problem driving my dually with "standard" steering, and I like having a direct connection between the steering wheels and the steer wheels. Our old Audi A8 had this feature; never cared for the changing ratios.
Old May 15, 2017 | 10:44 AM
kab449's Avatar
kab449
Has nothing to do with your skill level. Just allows you to accomplish the task quicker. Kinda like removing a bolt using a ratchet rather than a box wrench.
Old May 15, 2017 | 11:07 AM
fordmantpw's Avatar
fordmantpw
I like it. I don't really notice it working unless I think about it, which is the way it should be. Turns are much quicker at slow speeds, and backing the trailer seems simpler.
Old May 15, 2017 | 12:37 PM
TX03RUBI's Avatar
TX03RUBI
I have a F-350 CCLB without the adaptive steering. I don't think I'm missing anything. I specifically ordered my Lariat without after driving both versions.
Old May 15, 2017 | 05:51 PM
  #28
2009kr's Avatar
2009kr
My F450 is 4 turns lock-to-lock with the adaptive steering. That's the same number of turns as the non-wide-track trucks without adaptive steering. My wide-track means that my front wheels turn 45* instead if 38*, so the adaptive steering gives me 7* more wheel turn for the same steering wheel turn.
I like the adaptive steering a lot. With the F450, it actually feels quite "nimble" with the wide-track + adaptive steering. (I know how silly F450 and nimble sound together - you really need to drive one to understand.)
Old May 16, 2017 | 04:49 AM
  #29
shortride's Avatar
shortride
It will work great if you have a truck from now on with adaptive steering. My only point was, if you get used to adaptive steering and all of a sudden find yourself in a truck without it, it could be a bit of a challenge for some to back a trailer the old way. It's kind of like when I go to get into my new Platinum Super Duty I automatically reach into my pocket for my key when I don't need it.
Old May 16, 2017 | 06:04 AM
  #30
17f250ford's Avatar
17f250ford
I dont have it and i regret not getting it
Traded in my 15 f150 for my 17 SD and what a difference i need a football field to turn
