Any ideas?
Old May 13, 2017 | 05:33 PM
rowdyredneck's Avatar
rowdyredneck
That looks like a Motorcraft 2 bbl. Instead of a check ball for the accelerator pump they use a rubber umbrella type check valve that pushes through a hole in the carb body behind the pump diaphragm. It looks like this:
There will also be a small check ball with a weight above it located under the venturi assembly.
Old May 13, 2017 | 05:52 PM
RageOfAntioch's Avatar
RageOfAntioch
Yeah Its the original Carb
And it 100% had that I did not remove it I just replaced the Accelerator pump
Old May 13, 2017 | 06:48 PM
Franklin2's Avatar
Franklin2
That is very weak. I could only see little spits of gas. It should be long duration streams pouring in. That's your problem.
The other poster is correct, the Fords have the umbrella check at the diaphragm. And they also have a check under the venturi. The venturi are those two round things down in the carb in your video. I think I would pull the carb off you go to take those out. It's too easy to drop a screw down into the engine doing it on the engine itself.
Old May 14, 2017 | 12:55 AM
kr98664's Avatar
kr98664
Originally Posted by RageOfAntioch
I didnt want to buy 4 tires if I cant get it to run halfway decent
Who needs tires for a test drive?
All seriousness aside. The truck hasn't run for 20 years? Even if the carb was perfect, revving it while parked may not be enough to raise the engine from the dead. I've brought many an engine back from long periods of inactivity, but it usually took some hard driving to do so. Rings stick, valves get gummed up, etc. Revving with no load doesn't seem to do much. I've found if I can get an engine halfway driveable, a good (insert name of ethnic group) tuneup is what really cleans out the cobwebs.
Old May 14, 2017 | 08:03 AM
Gary Lewis's Avatar
Gary Lewis
The other guys have you headed in the right direction. But, just in case it is needed, I have some info on that carb on my web site: Motorcraft 2150 - ???Gary's Garagemahal.
Old May 14, 2017 | 08:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ummmm good question... Is there a ball in there? Any pictures?
I didn't realize it was a 2150.
So, did you really expect a 30 year old piece of rubber that has been sitting for the last 20 to seal properly?
I just replaced a toilet flapper that was about five.
Though I can't say if the rubber is different or the water is harsher than cruddy old gasoline.
Anyway, I'd certainly start with the cheap and obvious part.
Old May 14, 2017 | 08:27 AM
Gary Lewis's Avatar
Gary Lewis
Though I can't say if the rubber is different or the water is harsher that cruddy old gasoline.
Amen to that! And keep carb cleaner far from that valve. FAR! Don't ask.
Old May 14, 2017 | 12:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4AZ-9576-A .. Accelerator Pump Check Valve (Motorcraft CM-825).
Use with Auto-Lite/Motorcraft 2100 series & Motorcraft 2150 series 2V carbs.
RUSTY50F1
1978 - 1996 Big Bronco
Feb 6, 2015 05:00 AM
SimAngus
Oct 28, 2014 09:02 AM
ALedbetter1
Sep 21, 2013 07:01 PM
Michigan Rick
May 29, 2010 11:32 AM
tomhail
Feb 16, 2006 06:47 PM
