Problem with charging system
Old May 11, 2017 | 06:41 PM
johnw4jml's Avatar
johnw4jml
Hi All,
I have a 1990 f-150, 4.9lt the problem is I thought the alternator had gone bad so I took it up to the parts shop and pulled pulled it off and tested it, alt, reg and diode all passed but with it on the truck it will not charge right or charge at all, and while I am thinking about where is the relay for the intermittent wipers? I can hear just can't find it......
Old May 11, 2017 | 07:16 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Has anyone swapped the gauge cluster?
Does the charge warning (battery icon) light come on with the key in 'run' but before you start the engine?
​​​​​​​My older ('87) truck has the wiper speed governor right near the switch itself but in later trucks it is behind the glove box.
Old May 11, 2017 | 07:49 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Any squeals from the alt while running?
Old May 12, 2017 | 03:19 PM
johnw4jml's Avatar
johnw4jml
charging system problems
no, no noise at all. like I said they put it on a test machine and it checks out fine 14.2 output. but on the truck it does not???????
Old May 12, 2017 | 03:21 PM
johnw4jml's Avatar
johnw4jml
I found it finally, but now it's raining and I can't work on it, more on this later.
Old May 16, 2017 | 07:05 AM
dive2663225's Avatar
dive2663225
john,
you THINK the alternator has a problem? may i ask why? weak or dead battery, dim lights etc.?
if so maybe your battery has a bad cell in it and battery will not accept a charge properly.
#2 if the alternator worked well in the shop, then i would suspect the wiring to your alternator in the truck-
12V from ignition switch to ALT,
check the larger wire on the ALT marked Bat for continuity /fusible link,
GROUNDS
Im assuming you have hunted down the wiper relay maybe because of a short?
eigenvector
1983 - 2012 Ranger & B-Series
Oct 6, 2011 02:29 PM
kealan
Feb 19, 2011 09:37 AM
muff
1997 - 2003 F150
May 18, 2009 10:56 PM
Lead_Pusher
Apr 5, 2009 06:37 PM
traves
Dec 30, 2003 08:05 PM
