Engine Swap Question?
Old Sep 3, 2003 | 02:29 AM
bobcat360's Avatar
bobcat360
i have '87 F250 4x4 w/ 351W (one ton). the engine worked too hard to move this truck (underpowered) ,rear main seal leaking bad & smokes, she needs to be yanked. my question is : will a big block(460) bolt in without modifications?. motor mounts?do i need to swap trans.what do i need to do?
Old Sep 3, 2003 | 12:52 PM
Superdave's Avatar
Superdave
You did not mention if you have an auto trans.
But yes you would need a standard trans bellhousing or auto trans bellhousing bolt pattern that would match a 460 which can come from a 460 of course, or a 351M or 400. These have the exact same bolt pattern. You can get the engine frame mounts from Ford still to switch to a 460.
It is a very do-able job.
It will just take a little leg work. I did this swap in my 82 from a 400. It was frustrating at times finding parts. But well worth the effort.
Old Sep 4, 2003 | 01:05 AM
Superdave's Avatar
Superdave
bobcat360
I found these on ebay. This will take you all the way for the engine mounting part. These are exactly what you would need.
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33613&rd=1
