slave cylinder problems
Old Sep 3, 2003 | 05:15 AM
coolgreen's Avatar
coolgreen
Has anyone ever had a leaking slave cylinder?
Mine seems to be leaking at the fitting that goes into the slave cylinder. I'm not sure whether the cylinder itself needs replacing.
I tried to get the fitting off, but no luck. Must be a special tool of some kind.
I really don't want to have the shop pull the tranny out of this thing.
Thanks.
Old Sep 3, 2003 | 09:35 AM
alabamabuddog's Avatar
alabamabuddog
there is a white or light gray ringright where the hose goes into the cylinder body . I used a needle nose pair of pliers with a ring shape on the end ( you know , the ones you get at wal mart that are extra long ) push in on that ring then push the hose in and pull it out of the body . But this only gets the hose out , it will not do anything for the leak .
Old Sep 4, 2003 | 06:12 AM
coolgreen's Avatar
coolgreen
Well, $1,600 later, my truck is back on the road. Seems I needed a slave cylinder, a clutch and all the bearings. I guess snow plowing = a new clutch each year.
Next time I replace a clutch on an older vehicle I will replace the slave cylinder as well. Live and learn.
