Just wondering what the correct Ford part # for the Instrument Cluster Voltage Regulator would be?
I found an OEM p/n C9AZ10804A It is also called Motorcraft GR512
Oil/Amp gauges or Oil/Amp idiot lights makes no difference. The year does, because 1970 F100/350 & Econoline use one year only printed circuit boards.
1971/72 F100/350's & 1971/74 Econolines use different printed circuit boards and ICVR. 1967/69 F100/350's have an ICVR, but don't have printed circuit boards.
C9AZ-10804-A .. ICVR - Instrument Cluster Voltage Regulator (Motorcraft GR-512) / Obsolete ~ Available NOS & from auto parts stores.
Thanks Bill! Yeah I knew that 1970 was a one year only circuit board and that's why I wanted to make sure this was the correct regulator, and I meant to say the one I found was NOS. Thanks again
