Hey guys so I have a couple things that need to be addressed with my new truck. It's a 88 F250. Anyways I'm getting a flashing check engine light when I'm driving on the highway and the throttle is only being applied halfway. Checked codes, both engine off and on. Got 11 on both. But for stored codes I have 32 and 95. For code 95, the relay was sticky I think so I swapped it with the one from my f150 (same engine). For code 32, I thought the egr valve only acts up when idling? Truck runs great so I don't see what the problem is. Also my door latch decided to act up a bit. Its working now but what grease do i need to use to lube and clean it up?
If you grounded the pin #6 of the self-test plug this code CM95 is normal.
Else:
A Continuous Memory Code 95 indicates that one of the following intermittent conditions has occurred:
-- Fuel pump circuit activated when processor expected circuit to be off (i.e. fuel system test or prime procedure).
-- Open circuit in or between the fuel pump and FPM circuit at the processor.
-- Poor fuel pump ground.
-- FPM or Power-To-Pump circuit short to power.
-- Fuel pump relay contacts stuck closed.
-- Left/Front HEGO circuit short to power (dual HEGO).
Yeah something happened with the relay and the fuel pump was constantly running after the truck was turned off so I replaced the relay and all is good now
