Die cast model?
Old May 10, 2017 | 04:22 PM
Litre's Avatar
Litre
Die cast model?
Different type of question for you all...
I have a bunch of die cast models of the vehicles I've owned over the years (Corvette, BWM GS Adventure motorcycle, etc...). Have any of you found a '17 Super duty model out there yet? Google search didn't really yield anything, but I know there are just a ton of dealers/manufacturers of this type of stuff, so I'm hopeful one of you has found something out there.
Otherwise, I'll just chalk it up to it being too early/too new for the toy industry to catch up.
Thanks!
Old May 10, 2017 | 04:43 PM
KCJackson1's Avatar
KCJackson1
Licensing can be expensive, and some manufacturers are stingier than others about supplying documents as sensitive as design sheets to make die-cast models. Chrysler was quick to license the then-radical 1994 Ram design because they had nothing to lose and the publicity would help sales (I have two of the 1/18 models since I had a 1996 Ram). Ford won't gain much with such a Super Duty model, so they'd likely wait longer (if at all). The F-150 is more a consumer truck and sells much higher than the SD, so F-150 toys sell well and are worth it to Ford.
Old May 10, 2017 | 04:51 PM
Kingofwylietx's Avatar
Kingofwylietx
Originally Posted by KCJackson1
.......... Ford won't gain much with such a Super Duty model, so they'd likely wait longer (if at all). The F-150 is more a consumer truck and sells much higher than the SD, so F-150 toys sell well and are worth it to Ford.
I did a quick Google image search for Ford F250 and every iteration popped up...except the 2017.
So, since Ford has licensed them for what appears to be every previous generation, I would expect them to do for the current style. It looks like you are just a bit early to buy one, but I expect they will be out fairly soon.
Old May 10, 2017 | 05:00 PM
KCJackson1's Avatar
KCJackson1
The body was out for almost 20 years... changing the front clip periodically wasn't much of an adjustment when the rest of the truck was the same. If/when a model manufacturer gets the green light for this new SD, the major model retailers like DieCast Direct will get allocations first. I usually check with them if I'm looking for something in particular.
StrikeForce
Dec 13, 2017 07:13 PM
ArtsBest
2009 - 2014 F150
Jan 8, 2010 03:03 PM
Blowinsmoke
General Diesel Discussion
Aug 25, 2006 07:09 PM
elemint
6.4L Power Stroke Diesel
Feb 21, 2006 03:22 PM
tstpnb
Apr 27, 2004 06:59 PM
