Sorry this is a bit embarrassing of a question. But this is my first super duty and i know there is a lot to consider.
But is everyone using for a hitch receiver? I tow both ball sizes 1 7/8 and 2 5/16. On my F150 I just had a basic straight receiver with the 3 sizes you just turn for each one. This truck is higher though so should I just get receivers and a 4" drop or something?
I also don't some cheap **** given the towing capacity I have.
I never liked the universal type. I have two I carry. My pintal that is used with most of our equipment trailers and a 2" that is specific to a particular trailer. This way I never worry about height adjustment or weight.
Like most I have 4 different hitch bars purchased over time and seams like I had the wrong size ball needed on the wrong drop. I went with a Andersen Rapid Hitch 10' drop with a 2" and 2 5/16" ball.
Should have went this way a long Time ago.
Went with the Weigh safe 8" drop and 2" & 2 6/16 kt. Also went ahead and got the 1 7/8 so I will always be prepared. Nothing worse than needing to tow something and not being able to tow it.
Mine is 2.5" measured it to be certain.
17 F250 Lariat
I am actually very disappointed with the sleeve adapter/reducer. It had tons of play in it. I bought a different one and it is better but in the end I am going to search around for a 2.5" shank for my WDH for my Toy Hauler.
17 F250 Lariat
Travis, did you get our discount from the thread I linked? The Weigh Safe is a sweet hitch. I got the 1 7/8" ball too as well as the lock plate dust cover...
I have an early 2017 F-250 single wheel so I have the 3" receiver. I went with the Weight Safe with the 2" and the 2 5/16" *****. I don't know if I will ever use a 1 7/8" ball but I will buy one for just in case.
Mark
Mark, the 250's are unchanged from early to late builds. The HD 250's get the 3" and the rest get the 2.5". You must have an HD 250.
If you wanted less to keep up with it seems like the logical choice would be to have a receiver with 2 different size ***** on it. I've been lucky enough to have everything I tow to have a 2" ball.
