Instrument Cluster Wiring
Old May 10, 2017 | 11:56 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm on my phone so the diagram is tiny, but I don't see where coil power is going through the cluster.
​​​​​​​Seems like a lighting diagram.
I *do* see power from the switch going to the fuel injector cooling fan, so I think this diagram is for an I-6.
You could just use *either* the TFI coil wire *or* the DSII coil power wire on the DS inner fender to trigger a relay for your HEI, and then it would work with the key
Old May 10, 2017 | 12:37 PM
Mutilator712's Avatar
Mutilator712
Okay. Yeah I'll have to decipher stuff in a bit. I think this diagram is an "in general" diagram for all trucks/all engines. Cause this one also has a 4x4 switch and other stuff on it and mines two wheel drive, plus the other page that I have has all of the EFI wiring. So I think it's just a combo of all.
Old May 10, 2017 | 12:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Go to Gary's Garagemahal website and look at the ignition wiring section of the 1986 EVTM.
You can find diagrams for both DSII and TFI ignitions, with all the splices and connectors spelled out.
That manual breaks out each circuit individually, so there's not much distraction.
Old May 10, 2017 | 02:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Start & Ignition - ???Gary's Garagemahal
Page 29 and figure 20 on page 46 show your 5.0l as it should have come from the factory.
Hopefully most of these connections are still there.
Easiest would be to pick up circuit #20 W/LB near where the coil used to be and bring it over to the starter relay.
Mount an ignition relay next/near to that and bring power from the new ignition relay back to your HEI.
​​​​​​​But I have no idea how much, if any, of the original harness was hacked out by the person who swapped in the carb and HEI.
​​​​​​​The idea of a toggle ignition switch makes me think too many beers and not enough brain cells were involved
Mister_King
Electrical Systems/Wiring
Mar 6, 2015 06:45 AM
stoph8n81
Sep 4, 2014 10:37 AM
bryanmartin
Oct 27, 2013 09:37 PM
nomorehoez
Aug 12, 2010 10:48 AM
78'Ranger
Oct 15, 2007 09:40 PM
