farmboy57, the truck has very good bones [a good starting point]! Do the doors rattle? I ask because the plastic pieces are missing from the door latch striker. This is not uncommon and is easily replaced.
E9AZ-5422008-A (replaced EOTZ-1022008-A) .. Striker Plate-R/L same / Available from Ford & auto parts stores.
1980/91 Econoline front doors & body side hinged doors; 1980/96 F100/350 & Bronco // 1983/91 Crown Victoria/Mercury Grand Marquis/Lincoln Town Car (front/rear doors)/Mustang.
Would have been nice if we could just replace just the nylon sleeve, except that Ford decided to make the washer on the striker pin assembly non-removable, so now you have to buy a $15 part instead of a $1 part.
Would have been nice if we could just replace just the nylon sleeve, except that Ford decided to make the washer on the striker pin assembly non-removable.
So now you have to buy a $15 part instead of a $1 part.
How much in a junkyard (see post #18)? Maybe a coupla bucks each.
