Engine oil
Old May 9, 2017 | 12:01 AM
1911fan's Avatar
1911fan
Engine oil
I got my hands on 10 gallons of john deere torque guard 10w-30 its cj-4/sl rated. I checked the john deere website and it says its sl and sm rated. Think its safe to use? Any oil guys out there wanna chime in. Isnt the sl sm rating for gas engines?
Old May 9, 2017 | 04:48 AM
Just Strokin's Avatar
Just Strokin
what does the container have on the label as the rating? You can used C rated oils in a gasoline engine but not the standalone S rated oils in a diesel.
Old May 9, 2017 | 05:06 AM
senix's Avatar
senix
here is the list of approved oils
File Type: pdf
Old May 9, 2017 | 06:39 AM
System's Avatar
System
Prolocutor
That list is approved CK4. AFAIK, all CJ4 oils are fine and the OP listed his JD oil as CJ4. Should be good to go.
Old May 9, 2017 | 10:18 AM
1911fan's Avatar
1911fan
Thanks guys thats what i figured
Old May 9, 2017 | 10:19 AM
1911fan's Avatar
1911fan
The sl sm rating is just gas right should have no bearing on if its ok for diesel
Old May 9, 2017 | 10:55 AM
System's Avatar
System
Prolocutor
Right on. As long as it's CJ4, you're good.
Old May 9, 2017 | 02:07 PM
1911fan's Avatar
1911fan
Ok thank you
Old May 10, 2017 | 10:03 PM
bruceatlam's Avatar
bruceatlam
Just my two cents ---- if your warranty is of any concern to you, I wouldn't use it if it's not on Ford's list and I don't see it on the "approved" list.
Old May 11, 2017 | 05:25 AM
System's Avatar
System
Prolocutor
That list is for the new CK4 oils. ALL CJ4 oil is approved.
Old May 11, 2017 | 09:16 AM
1911fan's Avatar
1911fan
Im gonna use it. Between that and some 15w-40 i have laying around my next 4 oil changes are free except filters
Old May 12, 2017 | 12:50 PM
jschira's Avatar
jschira
Just an FYI. Ford does not recommend 10w-30 if running biodiesel.
Check your pump. Murphy Mart (Wally World) around me have a sticker on the pump saying the fuel is 5%-20% biodiesel.
Old May 14, 2017 | 10:21 AM
1911fan's Avatar
1911fan
Theres no bio any where within 80 miles of me
Old May 15, 2017 | 09:08 PM
Dakster's Avatar
Dakster
No bio within 2000 driving miles or so of me... I'd run your free CJ-4 oil too. While I prefer 5w-40, too many blackstone UOAs show that there is absolutely nothing wrong wtih 10w-30 oil. I like the 5w part of 5W-40 because of where I live...
kupaa
Oct 21, 2010 11:00 AM
RRranch
22
Feb 19, 2010 07:58 AM
Dads79
Jun 24, 2009 09:39 AM
rsylvstr
Oil & Lubrication
40
Apr 5, 2007 11:19 AM
gtm245
Oil & Lubrication
34
Jun 5, 2004 05:42 AM
