Do I just keep cranking? New HPOP and Injectors
#78
Taking the HPX off will noty cure your problem. I still have mine on with the T50 witch doesn't have check valves. But doing the Cody test will let you know if the 0-rings are leaking. At this point, I say IPR or loose nut on HPOP. I'd do the IPR first. Then Cody test, if okay check the nut. If you built up over 2K psi with the IPR discounted it should of started. Do you have the wait to start light on?
#79
on
Thank you for pointing that out again. I think that point has been missed several times which could still point to a bad IPR or improperly installed electromagnet, HPOP gear that is slipping on the HPOP shaft due to low torque on the HPOP shaft bolt, bad HPOP, or compromised o-rings on the injectors....listed from fastest/easiest to more time consuming/labor intensive/messiest.
Since there is no white smoke, is there fuel in the fuel rail in the heads?
#80
#81
on
I also read that you have a RR w FBD. Compressed air in the fuel rail will show 55 psi as well since the gauge cannot differentiate between fuel and air, hence, if there is no fuel and only air in the head then there will be no white smoke.
The reason that I ask if there is fuel in the fuel rails is due to the fact that some of ITP's RR's will require a manual purge/prime to remove the air from the heads. I have seen this on two occasions on two different trucks. One of them is in my signature. You actually have to disconnect the return line from the return manifold to remove the air from the heads. It will not build "fuel" pressure until you do this. I know it sounds hokey but, ITP told me that it does happen and they do not know why.
Even though you have only seen 250+ psi ICP with the ICP sensor plugged in, once the ICP sensor is unplugged and the PCM tells the IDM to fire the injector, that should be enough pressure for the intensifier piston to squirt some fuel into the cylinder "IF" there is some in the head.
Just pointing this out in case all else fails.
#82
#84
#86
Did you put the nut on the ipr the same way you had it? Maybe try reversing it. I'm not at my truck so I can't tell you which way is correct, but reversing mine fixed a no start after replacing the ipr. Like I said maybe I didn't have it tight the first time. It may not matter but at this point it's worth a try.
#90
Ok, so no start after injector/hpop replacement hmm? I'm to lazy to read from the beginning lol... You filled the oil rails and hpop with oil? Is the 42 Pin connector connected in the right direction? Have you checked your oil level? Are the uvc harness connected? Are the batteries full charged?
