Help with brakes
Old May 8, 2017 | 02:08 PM
kyle j's Avatar
kyle j
Help with brakes
Just finished up replacing the 2 brake lines on the master cylinder and one that crosses from front wheel to front wheel. After about an hour of chasing small leaks finally got around to bleeding the front wheels. Well with the truck running after I pump the peddle several times and the hold it it won't hold pressure? Not sure if it's related but when the truck is running and I'm pumping the brakes I can see the fluid in the master cylinder reservoir bumbleing? Any help appreciated not sure what to do next.
Old May 8, 2017 | 04:22 PM
knottyrope's Avatar
knottyrope
bleed the brakes all in the order of RR,LR RABS, RF, LF.
Old May 8, 2017 | 04:44 PM
kyle j's Avatar
kyle j
Thanks for the help is there a bleeder screw on the RABS valve?
Old May 8, 2017 | 05:28 PM
Red97350's Avatar
Red97350
Yes.
Red
Nseal1996
Jun 25, 2012 02:59 PM
okwaho1650
Oct 7, 2008 11:08 AM
SCFLATHEAD
Mar 1, 2006 12:36 PM
Danlaws
Oct 13, 2001 02:37 AM
