Before I buy
Old May 8, 2017 | 05:46 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Originally Posted by CountryBumkin
Just figure that "those couple of gaskets" will actually be the crank seals and head gaskets.
Enjoy
Yep....they will be the gaskets that scare the bejesus out of the current owner. Most likely because they have no knowledge about where to start. Do you have the ability to pull the engine ?
Old May 8, 2017 | 06:01 PM
Gary Lewis's Avatar
Gary Lewis
Head gaskets aren't all that hard. But there are things to watch for on a Windsor, and a 302 qualifies. One is the intake manifold. Many of them were aluminum and unless the owners down through the decades have been faithful about changing the coolant the intake may well have too much corrosion to seal up to the head. In that case, it is 4bbl time.
Another is the waterpump bolts. They are frequently corroded to the point that they twist off when you try to remove them. So, if you don't have to remove the water pump, don't.
Old May 8, 2017 | 06:14 PM
WhatsAChevy?
With that said,with good reason, engines are like Humans, regardless of mass production, they are all different in how they react, given their individual environment.
Old May 8, 2017 | 06:16 PM
bullnosebeginner's Avatar
bullnosebeginner
Yes I can pull the motor. Between the shop my grandpa and myself I should have all the tools I would ever need to do most things on this truck. Thanks for the input on the water pump bolts I wouldn't have thought of that.
Old May 8, 2017 | 06:19 PM
Gary Lewis's Avatar
Gary Lewis
Good project with your grandfather. Can't wait to do that with my grandson.
Old May 8, 2017 | 06:20 PM
WhatsAChevy?
Sounds like you have the support and resources to take this on...I say go for it ! We will be here along the way should you choose to share with us !
Old May 8, 2017 | 06:31 PM
reamer's Avatar
reamer
Shortbed? I like shortbeds......
Old May 8, 2017 | 06:34 PM
bullnosebeginner
Thanks for all the help so far, I welcome any ideas or tips you have keep it coming they're great. As for the truck I'm supposed to get more pics tonight or tomorrow so stay tuned for that and I hope to be able to buy it in the coming week
Old May 8, 2017 | 06:36 PM
Gary Lewis's Avatar
Gary Lewis
When replacing heads I like to take two long bolts the right size, cut their heads off, and use them as guidepins to install the heads. And, I do the same on intakes, but use 4 bolts there.
Old May 8, 2017 | 06:37 PM
WhatsAChevy?
I say pull the trigger...We "Got Yer Six !"
PHXCobra
17
Nov 23, 2013 10:27 AM
83capril
Vehicles for Sale
Sep 21, 2011 11:05 AM
hiram6
19
Feb 27, 2009 01:49 PM
Dlobacz
Dec 3, 2007 09:03 AM
idfergusson
25
Dec 2, 2006 10:13 PM
