Modular V10 (6.8l)
New Excursion has a tuner?
Old May 8, 2017 | 07:49 AM
rock2610d's Avatar
rock2610d
2001 V10 4x4 XLT, 203,000 miles.
Got my 3rd excursion a couple months back with a bad motor. Holes in block.
Finally got new motor in 2000 V10 out of another excursion with 119,000 miles on motor.
Took it for its maiden voyage yesterday and WOW, it's seems to be much more responsive then my other stock 2000 excursion. My stock X will shift at about 2000 rpm while driving easy. This one shifts at 2500 to 2800 rpm driving normally. Very "peppy" and shifts smoothly.
Is there a way to tell if the 2001 X has been tuned?
I have a SCT tuner but it's mated to my supercharged excursion. Not sure I can use it to log the 01 X.
What should I look for to determine if it's chipped or tuned?
Previous owner had to return to Mexico, so I have no idea how to get in touch.
Old May 8, 2017 | 08:55 AM
z31freakify's Avatar
z31freakify
What gears does it have? And what gears did your old X had?
Old May 8, 2017 | 09:16 AM
rock2610d's Avatar
rock2610d
I have 3 excursions.
2 each 2000 v10 4x4
1 has a supercharger on it with OEM 4.30 gears limited slip.
1 is bone stock with 3.73 gears (this is comparrison vehicle)
1 each 2001 XLT V10 4x4 with 3.73 gears....limited slip.
Seems like it has a tune on it. I'm worried I should have put higher octane gas in it. Currently 85 octane. Unless there was a transmission shift strategy change between 2000 and 2001.
Old May 9, 2017 | 08:48 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The tuner should work on everything up to maybe even 2010+ cars for reading OBD-II stuff like engine pids.
I'm not sure off the top of my head how you'd figure out if it had a tune.
Linking in 5-star
Old May 9, 2017 | 11:54 AM
rock2610d's Avatar
rock2610d
Hooked up SCT tuner and it did a record of data.
Going to hook up tuner to computer and do a real log with livelink gen2 to see if I can tell if anything is non oem.
Old May 10, 2017 | 03:38 PM
rock2610d's Avatar
rock2610d
Well, I'm no expert with the Ford PCM. Don't know which PIDS to select to determine if a tune is present.
I guess at this point the easiest way to check is to swap my 2001 PCM into my 2000 and see what happens.
So, is there a seperate computer that controls the transmission, as I will need to swap it too?
Old May 10, 2017 | 04:42 PM
krewat's Avatar
krewat
PCM is Powertrain Control Module - it does everything.
Old May 12, 2017 | 05:45 AM
Im50fast's Avatar
Im50fast
85 octane? I wouldn't use that in a lawnmower.
Old May 12, 2017 | 08:30 AM
rock2610d's Avatar
rock2610d
Above 5000 feet in elevation, 85 is equal to 87 octane.
You must be from the low lands
rock2610d
Computer Chips & Tuners
May 10, 2016 02:18 PM
motopsyko32
Vehicles for Sale
May 22, 2010 04:17 PM
PhoenixRisen
Vehicles for Sale
Mar 20, 2010 05:48 AM
mgmoore7
Mar 4, 2010 10:53 PM
99tjrockcrawler
Jun 12, 2003 02:47 AM
