Heim joint question
Old May 7, 2017 | 11:22 AM
Skagewa's Avatar
Skagewa
Heim joint question
Hello again my Ford brothers!
So I previously posted about the master slave cylinder but to my surprise after I met with my mechanic I have to install a heim joint for my clutch lever or something (I'm no mechanic so excuse my lack of knowledge) in order to fix the problem.
I did a little bit of digging regarding buying the part so I bought the part on ebay but the question is since it said it was a fix for 87 and up but didn't have anything for my particular model. The mechanic told me that the part was this heim joint on ebay I ended up buying but I was hoping if you guys could answer my question regarding if this part will work on my model? I have a 1986 ford f250 6.9 idi. The mechanic said it would work but I thought I'd ask you guys if I would be able to install it myself and if it is the right part? If so, is this something I would be able to do myself with instructions?
heres the part btw
FORD Clutch Rod, PERMANENT fix/repair!! POWERSTROKE, SUPER DUTY, BRONCO | eBay
Thanks again everybody I appreciate it.
Old May 8, 2017 | 08:58 AM
IDIoit's Avatar
IDIoit
wow that's pretty expensive for a heim joint and a bolt.
if youre not mechanically inclined, I would say to let your mechanic do it.
but then if your mechanic was any kind of mechanic, he could have made one for you for that price.
I purchased one from my local race shop for 7 bucks, and a 2 dollar bolt, then welded them together.
Bryce05
Jun 3, 2019 05:53 AM
iiSTATUSii
Jul 10, 2018 05:52 PM
carl2591
21
Apr 23, 2018 05:35 PM
fabmandelux
Oregon Chapter
38
Nov 7, 2010 05:08 PM
Boris2000
Computer Chips & Tuners
Mar 21, 2010 09:54 AM
