Need help on 1996 f350
Hey there everyone thanks for reading and helping me out so my 1996 f350 I've had for a year with little to no issues but 2 days ago I was driving home from work and it died it sounded like it ran out of fuel but I had a full tank so I had a buddy stop down and he turned the key a bunch to get the pumps going thinking I had air in the line and it started up and was fine then the next day I was driving to my hunting property and it did the same thing so I thought maybe it's the rear tank so I switched to the front one which I had filled up before we left and 2 min later same thing it's like it's not getting enough fuel at random times and cuts out so then I drove it back home...it did it 4 more times and now it's sitting and I can't figure it out I also have my battery light on right now it's been on for like 2 weeks but everything runs fine so I haven't worried could it be what's causing all this ? Or does anyone have a clue ? Thanks for the help !
Do you have a check engine light on? Unless you have converted to electric fuel, repeatedly turning the ignition switch on and off does nothing but energize the glow plugs, as the OBS trucks have a mechanical fuel pump. Grab a helper, and with a cheap pencil type tire gauge check the fuel pressure at the Schrader valve on the fuel bowl, while cranking the engine. You should have a minimum of 20lbs, while cranking, around 50lbs while the engine is running. The CPS can do funny things. At around 25 bucks it can be changed out fairly cheaply. If it doesn't fix the problem, you have a spare for the glove box. Use a Motorcraft or IH CPS only. My 96 C&C truck would die randomly, sometimes it would fire right back up, and other time it had to sit for 5 min. It had a check engine light, and pulling the codes showed a bad IPR. What does the voltage gauge read? Both high and low voltage can trigger the battery light. Some places to start.
How do you know it isn't getting any fuel?
Tom gave some info on how to check fuel pressure but I didn't see any feed back where you had checked it. As was mentioned, turning the key on a stock truck will not do anything for the fuel pump. It is mechanically driven, so the motor has to be turning for it to work.
have you checked the condition of the fuel filter?
