99 Expedition Transfer case
Old May 6, 2017 | 08:41 AM
Ontomuch's Avatar
Ontomuch
Hello thank you for having me on the forum.
I have a 99 Eddie Bower edition and I was driving down the road then all of a sudden it at a stop light it wouldn't move. I can hear it changing gears but it will not engage. I had a guy come hook up his computer and he said it was the transfer case. I was wondering if I need to replace the entire transfer case or can I just get a new motor or maybe something came loose? When I looked under the truck it looks like the drive line is slipped out about a 1/4" any suggestions???
Thank you
Old May 6, 2017 | 09:32 AM
alloro's Avatar
alloro
Something snapped inside the t-case, so you're either going to pull it apart to see what's wrong and repair it or just grab one from a junkyard and swap it out.
Old May 7, 2017 | 09:13 AM
Ontomuch's Avatar
Ontomuch
Thank you
I'm going to have it pulled and open it up. I'm hoping that I can just fix it. I don't want to have too get a new one. How hard are they to pull? Do I need a transmission jack to safely lower it? I've worked on plenty of engines but never this before.
Old May 7, 2017 | 10:23 AM
alloro's Avatar
alloro
They're not as heavy as an automatic transmission and you can lower them with a floor jack. You've just got to do some balancing with it.
Old May 7, 2017 | 11:22 AM
Ontomuch's Avatar
Ontomuch
That's good to know. I was told that there was a swing arm that swung it out and down. I thought that may have been a crock.
Old May 7, 2017 | 03:33 PM
alloro's Avatar
alloro
Someone is probably thinking of the torsion bar that has to be removed.
Anyway, here is the procedure so you can see what to do.
File Type: pdf
Old May 7, 2017 | 09:02 PM
Ontomuch's Avatar
Ontomuch
That will come in handy. Thank you.
jakvisualdesign
Feb 28, 2016 08:28 PM
Doowop
Feb 14, 2005 12:37 PM
brian931
1983 - 2012 Ranger & B-Series
Dec 5, 2004 05:35 PM
tw
Jan 11, 2003 04:43 PM
