Trailer sway
Old May 7, 2017 | 03:13 PM
  #46
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by R&T Babich
When you go straight over speed bumps or dips the anti-roll bars add nothing to waddle.
y.
If only the world was Straight
Old May 7, 2017 | 03:56 PM
  #47
jh818's Avatar
jh818
Originally Posted by pirate4x4_camo
If your ex feels squishy towing with 265/75r16 tires @55 psi you likely have other handeling related issues. 55psi in those tires will support the full gvwr of the Ex.
Seriously, if you arrived at 80psi by trial and error testing I would go back to 55psi and look for the real problem. My guess is you either have a worn out shock or simply need shocks with more compression and or rebound valving.
Also, since you mention E rating I assume you are not running a "P" or passenger vehicle tire but it is worth checking.
I don't have any issues with swaying on my setup. I don't even have anti-sway with my WD hitch. I was told by rv'ers to pump the tires up. I do have LT tires.
Old May 7, 2017 | 09:06 PM
  #48
jspence105's Avatar
jspence105
I use 60 front and 65 rear. I used to drop it when not towing but it's easier to just keep it there.
Old May 7, 2017 | 10:34 PM
  #49
pirate4x4_camo
What size tire ?
Tire pressure needed is dependent on a tires air volume and the load it needs to carry. The more volume a tire has the less pressure it needs to support the same load.
Load and inflation tables.
https://toyotires-1524598101.netdna-...s_20170203.pdf
Looking at the stock 265/75r16 you see that @55 psi each tire will support 2625 lbs or 5250 pounds for both, which also happens to be the GAWR of the rear.
hasteranger
Nov 24, 2016 05:01 PM
1buckeyefan
Jun 29, 2011 11:33 AM
Hendog
2004 - 2008 F150
May 2, 2009 03:07 PM
676869Ford
Mar 7, 2008 10:18 PM
psmith338
May 4, 2005 08:31 AM
