Condensor at voltage regulator...
Old Sep 2, 2003 | 08:09 PM
jds1971's Avatar
jds1971
...can you use a points condensor to replace it or is the one at the voltage regulator special? The parts guys don't know where to look.
Joe
Old Sep 2, 2003 | 08:15 PM
Mil1ion's Avatar
Mil1ion
That's a choke to help get rid of alternator whine.
The values show be printed on there,so it's best replaced with the same part.
Old Sep 3, 2003 | 03:04 AM
willowbilly3's Avatar
willowbilly3
I was always told it was for eliminating the alternator whine in the radio. If this is true and you don't have alternator noise coming through the radio then you don't really need it. You see pickups that never had one so I'm not sure of the criteria for mounting it.
Old Sep 3, 2003 | 05:58 AM
jds1971's Avatar
jds1971
I've installed points condensors on coils where there wasn't one originally to eliminate ignition whine where a high output stereo was installed.
I'll check mine for a value this afternoon and see if I might be able to find one at Radio Shack- I searched MotorHaven but all I could find was decals when searching for "voltage regulator" or "regulator".
Thanks for the input fellas-
Joe
Old Sep 3, 2003 | 10:15 AM
BB's Avatar
BB
I have heard that if you use a solid-state regulator you don't need the noise supression cap. Never checked it out though.
Barry
Old Sep 3, 2003 | 01:31 PM
Mike W's Avatar
Mike W
You don't need it. If you get alternator whine, a in-line choke filter installed at the radio works. Radio Shack has them.
Old Sep 3, 2003 | 01:38 PM
BB's Avatar
BB
What I have read is the supressor on the regulator is for the old style mechanical regulators with relays which make a lot of RF noise. Alternator whine can mean a shorted or blown diode(s).
Barry
alvald83
Jun 17, 2010 03:52 PM
purplegoat
1978 - 1996 Big Bronco
Aug 10, 2008 04:04 PM
MercM47
Jun 30, 2003 11:37 PM
prginocx
May 25, 2002 07:50 AM
